Help Quick
Old Jan 19, 2005 | 11:30 AM
tb8125's Avatar
Help Quick
Hey guy i have a 88 camaro tbi 305 I found a 85 corvette motor sinus transmission I will also be getting the harness and ecm . I was wondering if you guy thought it would be a good buy. How much modification would i have to do the camaro to make it work HELP HELP
Old Jan 22, 2005 | 08:55 PM
88fbird's Avatar
Car: 84 S-10:(
Looks like you will need to remove the 305, harness, and ecm. Then install the stuff from the vette. It should be straight forward.
FBird
Old Jan 23, 2005 | 09:14 AM
kevinc's Avatar
Car: 1982 Z28
Re: Help Quick
You want us to decide how good a buy it is with no price listed...
It's basically a combined 305 to 350 swap as well as a TBI to TPI swap. Plenty of info in the Engine Swap board, take a look and see how complicated you think it will be.
Old Jan 23, 2005 | 05:06 PM
tb8125's Avatar
The engine and everything else cost 300 bucks
Old Jan 23, 2005 | 07:23 PM
88fbird's Avatar
Car: 84 S-10:(
Not bad. Do some research on the swap board then go put it in. It is only nuts, bolts, and a couple wires.
FBird
F-body-fan
Jan 12, 2023 01:49 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
meeklay812
Oct 1, 2015 03:46 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
3.8TransAM
Sep 27, 2015 08:37 PM
