Rocker Ratios
Old Jan 22, 2005 | 01:39 PM
BC GTA's Avatar
Car: 1989 GTA
Engine: 5.0 TPI
Transmission: T-5 WC
Axle/Gears: Yukon 3.73
Rocker Ratios
Under the tech section on camshafts I saw the following information for camshafts for my 1989 GTA 5.0 Liter 5-speed. A rocker arm ratio of 116/-118. I thought rocker arm ratio's were expressed as ratios such as 1.5:1 or 1.6:1. These figures look like degrees but I am not sure. Also, does anyone know the cylinder head flow ratios in CFM at .1, .2, .3, .4, .5 & .6 inches of value lift of a stock 5.0 Liter head. I am trying to determine if going from a gross value lift of about .48 inches with my camshaft to the low .5 inches with 1.6 ratio rocker arms would be beneficial. It may be the flow characteristic of these heads fall off significantly after .48 inches. Of course the higher rocker ratio would open the valves faster at the lower lift ranges.
Old Jan 22, 2005 | 08:45 PM
88fbird's Avatar
Car: 84 S-10:(
Your 5.0 should have 1.5 ratio rockers. I changed mine to 1.6s when I had the 305/5-speed. It is a pretty good improvement. Works well with a AFRP and exhaust.
FBird
Old Jan 23, 2005 | 04:39 PM
BC GTA's Avatar
Car: 1989 GTA
Engine: 5.0 TPI
Did you have to modify the inside of the stock valve covers? When I got my rebuilt engine from GM it came with these ugly valve covers and I am considering acquiring the stock valve covers.
Old Jan 23, 2005 | 07:26 PM
88fbird's Avatar
Car: 84 S-10:(
I used the stock covers. I'm actually still using the 1.6s w/stock covers on my current heads. Still running strong.
FBird
InfernalVortex
Apr 20, 2021 11:31 AM
Vincent135
Sep 28, 2015 10:50 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
Damon
Sep 26, 2015 04:29 PM
TX-SleeperC5
Sep 24, 2015 03:13 PM
