egr sensor
Old Jan 22, 2005 | 09:23 AM
lawrence_1md's Avatar
Car: 86 MonteSS/ 92 Camaro RS
Engine: 350 TPI / 305 TBI
Transmission: 200R4/ 4L60
egr sensor
Does anyone have the gm part number for the egr diagnostic temp sensor?
I can not locate one anywhere... the dealer here says the tpi did not come with one.
I was told my intake came off of a 86 corvette.
I am getting a code 32... when I went to troubleshoot it the sensor hole had a plug in it... the wire was not hooked up.
Thanks!
Matthew
Old Jan 22, 2005 | 01:42 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
The intake may be off an '86, the real question is what ECU and harness are you using?
Old Jan 22, 2005 | 03:36 PM
the wiring harness and ecm is from an 87 camaro.
Old Jan 22, 2005 | 04:45 PM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Re: egr sensor
Thanks!
Matthew
Couldn't find OEM oart number.
EGR Thermal Switch Wells EDS4 AutoZone $48.99+tax
Old Jan 22, 2005 | 09:57 PM
tried autozone and they have to special order it.. there is an extra fee which makes it not worth buying there not to mention the long wait.
Old Jan 22, 2005 | 11:20 PM
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
Here's the OEM part#14087416 NAPA part#CRB229130 don't know why the Echlin sensor is less expensive $10.99, but still special order.
I priced it three years ago at Autozone and it was $90.
You know you can wire a switch to the connector to ground and just switch it on after the engine reachs normal operating temperature until your find a sensor, or order one, just don't forget to switch it off before cold starts.
Old Jan 23, 2005 | 09:29 AM
thanks!
I will let you know what I come with on monday.
gta892000
Aug 11, 2019 11:16 AM
sailtexas186548
Feb 17, 2017 03:07 PM
92firebirdguy
Sep 1, 2016 07:53 AM
m00n420
Sep 11, 2015 02:39 PM
Kenwood
Sep 11, 2015 12:50 PM
