Test for leaking Injector?
Old Feb 6, 2005 | 09:25 AM
Redbird350's Avatar
Car: 89 Formula 350
Engine: L98 350
Transmission: T-5 Manual
I searched but did not find a definate answer to this question. I am in the middle of an intake gasket replacement on my 89 L98. I want to test for a leaking injector. Can I pull the fuel rails up and turn on the key and watch for fuel to come out of any injector indicating that one is leaking? Is there a better way?
Old Feb 6, 2005 | 10:48 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Jumper the fuel pump relay and have the rail sitting above a pan.
We had a leaking injector and leaking CS Injector on my friends Z and that is what we did.
Old Feb 6, 2005 | 11:42 AM
robsgta's Avatar
Car: 88GTAnotchbac/91 -Z/66 Chevelle
Engine: All strokers
Transmission: Pro built 700r4's
I found one on my friends car by pulling the plugs. One injector was darker with fuel than the rest.
But if your going to replace it any way I would raise the rail up and place them under pressure and see, your going to be doing that any way Right ?
Old Feb 6, 2005 | 12:49 PM
Redbird350's Avatar
Car: 89 Formula 350
Engine: L98 350
Yes its coming apart either way because of a leaking intake gasket. Just wanted to check the injectors while I was at it.
jklein337
Sep 19, 2018 06:23 PM
mike_c
Aug 27, 2015 04:32 PM
Jae992
Aug 27, 2015 09:07 AM
TheExaminer
Aug 26, 2015 04:59 PM
