Fuel Pump Stays on when the car is off ?!
Old Feb 8, 2005 | 06:07 PM
Bruticus's Avatar
Ok I did a search I think I narrowed it down but I will explain my situation and take some of your suggestions. Ok I have a 87 IROC 5.7 TPI now when I turn off my car the fuel pump will remain on even after the key is out the ignition. So I opened the hood and unplugged the battery once I did that of course the pump went off.
Now when I plug the battery back in I hear something click on and then it sounds like something is filling up and yes the pump is on when this is all happening. I was told that the fuel pump relay maybe stuck and keeping the fuel pump on. I was also told that there could be a loose ground somewhere. So any suggestions or do these seem to be logical oh yes the car does start up and run too. Thanks in advance.
Old Feb 8, 2005 | 06:09 PM
anondude13's Avatar
Take a look at the wire diagram and get an ohmmeter. Just FYI, the oil pressure switch one item that controls the fuel pump, if it thinks your pressure is high when your car is off it will turn the pump on. You may want to look into that.
Old Feb 8, 2005 | 07:09 PM
Bruticus's Avatar
So if its tested bad then I would need a new Oil Pressure Switch then where is the Switch located at. Anyone have any pictures of where the Oil Pressure Switch is located at ?
Old Feb 8, 2005 | 07:27 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
see that fitting that is circled, that is where the oil pressure switch should be located.
Old Feb 8, 2005 | 07:54 PM
Bruticus's Avatar
Hmmmm looks easy to reach I am leaning towards the oil pressure switch cause the fuel pump relay has already been changed like 2 weeks ago. Has anyone changed the oil pressure switch is it a easy task ?
Old Feb 9, 2005 | 12:34 AM
Zepher's Avatar
IT is really easy if you pull the distributor out since it is right behind it and behind the oil pressure sender.
Old Feb 9, 2005 | 01:06 AM
anondude13's Avatar
Should look like this right here:
Old Feb 9, 2005 | 01:25 AM
Bruticus's Avatar
Ok kool thanks alot for that picture that helps a whole lot I will go get one and install it tomorrow. I will keep you fellas posted.
Old Feb 9, 2005 | 03:21 AM
Zepher's Avatar
The one I had looks different than that one.
Mine had 2 spade ends on it, same type of ends that are on the bell style oil pressure sender (sender only has one spade edn on it).
I've got one in the garage and I'll post a pic of it tomorrow.
Old Feb 9, 2005 | 04:32 PM
Bruticus's Avatar
UPDATE!!!
Ok I changed the oil pressure switch still the same problem the pump still stood on. Next step bought a fuel pump relay changed that still stood on. Took it to a mechanic I know he opened the hood and to the left of where the battery was he opened up something with a fuse in it. Once he took out the fuse the noise stopped . But it seems the car needs that fuse or it wont start anyone have any suggestions ?
Old Feb 9, 2005 | 06:38 PM
Zepher's Avatar
Bad ECM or a jumper in the ALDL connector, or a short under the dash near the ALDL would be my guesses.
Old Feb 9, 2005 | 09:25 PM
porkyzilla's Avatar
Car: 89 iroc-z 5.7tpi 350,
Engine: 5.7tpi 350,
that would be correct if you short out 2 of the connectors on the aldl connector it turns the fuelpump on...and leaves it on... its used for measuring fuel pump flow,
Old Feb 9, 2005 | 09:36 PM
Bruticus's Avatar
So this thing with the fuse in it is called the ALDL dont mind the newbie question what does that mean.
Old Feb 9, 2005 | 09:39 PM
Zepher's Avatar
No, the fuse near the battery is the ECM main power fuse.
The ALDL connector is the connector on the bottom right underside of the drivers side dash. This is where you plug in a scanner or jumper the connections to read the SES codes or turn on the fuel pump.
Old Feb 9, 2005 | 09:53 PM
Bruticus's Avatar
So if the wires to the ALDL are messed up the mechanic would have to replace the wiring there right ?
RazorN8
Jan 7, 2022 11:44 AM
theshackle
Mar 5, 2017 06:37 PM
beachrodder
Aug 25, 2015 08:05 AM
justin57
Aug 20, 2015 07:05 PM
Kaweh
Aug 9, 2015 02:54 PM
