Injector I.D.--Can someone help identify?
Old Feb 8, 2005 | 09:51 PM
smitty62's Avatar
I'm putting a JY TPI on my truck. The injectors that are in it have no name that I can find. The numbers are: 621022 and opposite side: D1810AA. There is a green ring around the top. ID help as to the # rating and manufacture would surely be appreciated!
Old Feb 9, 2005 | 12:45 PM
DeepSouth_454's Avatar
Can't help you with the numbers. But do you know where the TPI came from?
Old Feb 9, 2005 | 11:31 PM
burnout88's Avatar
Car: 88 IROC
Axle/Gears: 10 bolt 3.73
I checked the injector part listing that I have on file. And that number is not listed. I think they may be some type of Ford injector based on the number sequence. Try a ford dealer and see if they can run those numbers for you.
Old Feb 10, 2005 | 12:09 AM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Re: Injector I.D.--Can someone help identify?
From the research i did they are 24# Lucas injectors...the number 621022 is a lucas number and the D1810AA appears to be a Delphi number. Hope that helps.
Old Feb 10, 2005 | 07:21 AM
smitty62's Avatar
Hey Capt! Thanks a bunch! "Make it so" and "Peace be with you"
Old Feb 10, 2005 | 11:56 AM
Your quite welcome number one....
92-Formula
Dec 12, 2015 10:34 PM
Linson
Sep 21, 2015 01:08 PM
abrilnelson89
Sep 17, 2015 10:41 AM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
