L31 heads, some Questions
Old Feb 10, 2005 | 05:44 AM
swisscheese's Avatar
Car: '91 Z28
Engine: LB9
Will the stock manifolds bolt right up to the vortec heads or do i have to do some custom work?
Also can i slap them on my 305 or is the combustion chamber much to big?
Pat
Old Feb 10, 2005 | 01:22 PM
dyeager535's Avatar
Car: Which one?
Engine: 355
Transmission: 465
The vortecs use the "stock" 6 bolt manifold pattern. I know in the 80's some manifolds used the 7th bolt, they won't work since there is no 7th bolt hole in the Vortec heads. The ports will line up regardless though, same exhaust port location as all other SBC's. Believe the difference in the manifolds is the above plug style log manifold won't fit, all the ones that aren't log style will.
From my understanding the combustion chamber of the 350 Vortecs (64CC) is bigger than the 305's, which were (universally?) 58CC. Supposedly there were 305 Vortecs, not sure on that though.
Old Feb 11, 2005 | 11:13 AM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
I've been running stock manifolds for over a year now without that last bolt towards the rear of the passenger side head (this is on my e-tecs).. Just make sure you use a good gasket and torque the rest of the bolts evenly...
Old Feb 13, 2005 | 06:09 AM
Car: '91 Z28
Engine: LB9
Thanks for the answers, that clears some things!
Pat
Old May 14, 2005 | 06:44 PM
markuzzz13's Avatar
Car: rally sport camaro
so you can out the L31 vortec heads on a 305 and have it run with changing any thing ?.......also whats the difference between the 906and the 062?....
MustangBeater20
Oct 29, 2022 09:20 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
