fuel pump
Old Feb 20, 2005 | 07:54 PM
davekrone's Avatar
fuel pump
I have a 1985 trans am with tpi,. when it is cold it hesitates severely. My mechanic told me it was the fuel pump/ When the car warms up it runs fine/ Is there anyway I can raise the fuel pressure without replacing the fuel pump? And in case I have to replace the fuel pump, is there anyone who has a procedure for that? Thanks.
Old Feb 20, 2005 | 08:13 PM
brutalform's Avatar
I dont believe it is the pump. Get a guage and test it. It would be doing it all the time. Maybe a bad cold start injector??? Never dealt with the cold start injector before. Any codes? Raising the pressure would help a failing pump die quicker anyway.
Old Feb 20, 2005 | 08:18 PM
davekrone's Avatar
Car runs fine when warm though, so I will ask him Monday if thats something worth checking. Thanks.
Old Feb 20, 2005 | 08:20 PM
davekrone's Avatar
How can I check the fuel pressure?
Old Feb 20, 2005 | 08:21 PM
brutalform's Avatar
I think the cold start gets it started, but does not have anything to do with it staying running. If it were the pump, should act up all the time.
Old Feb 20, 2005 | 08:25 PM
brutalform's Avatar
Connect a guage with a long enough line to the scrader valve on the pass. side fuel rail.(looks like a bicycle tire valve). Tape the guage to the windshield, and go for a ride. The pressure should stay steady at WOT. If its dropping, you are volume limited, and the pump is probably bad. The pressure should be approx. 36-38 psi at idle and go to about 43-45 at wot, and not drop.
Old Feb 20, 2005 | 08:28 PM
brutalform's Avatar
Oh, to just check the pressure, have the gauge hooked up, and with the car idleing, disconnect the vacuum line off the regulator. This reading is what your pressure is. This is not going to help you. You have a hesitation problem.
Old Feb 20, 2005 | 11:05 PM
davekrone's Avatar
I talked to my mechanic tonight and he checked the fuel pressure, it is very low at idle when cold and normalizes when it warms up. it is right where it is supposed to be at WOT. I asked him about a cold start injector and he said the car wouldn't start at all if it was bad.
Old Feb 20, 2005 | 11:07 PM
davekrone's Avatar
I looked online and there is a cold start valve. That might be it, it is hard to start when cold.
Old Feb 21, 2005 | 12:02 PM
brutalform's Avatar
Yea, thats what I thought about the cold start inj. too. ...Just wasnt really sure.
Old Feb 22, 2005 | 06:02 PM
davekrone's Avatar
well I drove the car today and it hesitated for awhile, when it got up to temperature the check engine light came on then went off when I hit the gas. It took about 20 minutes of driving till it improved, but it ran o.k., at least it was driveable after 20 minutes, but I had to drive it for 20 minutes to get it driveable .
When I jump on it, even when cold, it does not bog or hesitate, only when its at idle and you get on the gas. So I am hoping that it is not the fuel pump. I know this car has a knocks sensor, could that be a possibility? I will look into the cold start injector valve further. It is getting proper fuel pressure at idle and at WOT, but it gets very low fuel pressure at low rpms when driving., even when warm and gets above where it supposed to be at higher rpms. I don't know what it could be.
Old Feb 22, 2005 | 10:42 PM
brutalform's Avatar
Retrieve the code from the ECM, now that the CE came on.
Old Feb 23, 2005 | 09:41 AM
davekrone's Avatar
no codes came up, fuel pressure is normal when warm, but not when cold, the cold start injector won't cause that. How much will it cost to replace the fuel pump at a reputable shop?
Old Feb 24, 2005 | 06:21 PM
davekrone's Avatar
ok 2 codes came up this time, the first is code number 34
Mass Air Flow Sensor
voltage is too low
next code 44
oxygen sensor lean
Old Feb 25, 2005 | 01:00 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
... It is getting proper fuel pressure at idle and at WOT, but it gets very low fuel pressure at low rpms when driving., even when warm and gets above where it supposed to be at higher rpms. I don't know what it could be...
Have you thought about the fuel pressure regulator? diaphram spring may be getting weak.
Old Feb 25, 2005 | 01:25 AM
davekrone's Avatar
no I haven't, what would tell me that, thats the problem?
Old Feb 25, 2005 | 03:30 AM
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
I can't tell you what the problem is, you haven't posted having checked it, that's why I asked, it's the only thing left in the fuel system. if it's not that then you've come full circle back to the fuel pump, the regulator is easier to change.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
