Replaced Charcoal Canister but.....
Old Feb 22, 2005 | 03:15 PM
Mike86Z28's Avatar
Car: 98 Z28
My old canister part number was 17088067 and I read on here during a search that the replacement is part # 17092110. The only problem is the new canister does not have the electrical plugin like the old one did. I started my car and let it run for a few minutes w/ the replacement and the SES light never came on. I also checked for codes and didn't get any.
The reason I replaced it is because of a strong gas smell from the front of the car. Sometimes I could even smell it while driving and other times just after I killed the car and walked around the front of it.
Is it safe to say I am ok if I don't get any codes or should I try to locate a charcoal canister w/ the electrical plugin?
Old Feb 22, 2005 | 03:21 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
Correct replacement is 17092109 (for an 88 Z) and has the solenoid.
I would use the one it's supposed to have for it to function correctly.
Old Feb 22, 2005 | 03:27 PM
Mike86Z28's Avatar
Car: 98 Z28
Thanks for the quick reply. I just ordered the correct canister with the # you gave me. Thanks again.
Old Feb 26, 2005 | 02:39 PM
Vader's Avatar
Before you replaced the EVAP canister, did you try installing a new filter on the bottom of the old one to allow it to purge? The '86 still used the filter:
Old Feb 26, 2005 | 02:43 PM
Vader's Avatar
Sorry. I missed the part about the '88 in your signature. I was looking at the User Name and presumed it was an '86. Just slap me....
You CAN get just a replacement purge solenoid, instead of the entire canister.
Ghettobird52
Jul 5, 2024 11:18 PM
Casey Meyers
Mar 2, 2016 10:46 AM
69 Six Pack
Oct 5, 2015 07:51 PM
BurlyChev
Aug 16, 2015 09:08 PM
Mister_Johnny99
Interior Parts Wanted
Aug 14, 2015 12:59 PM
