TPI setup question
Old Feb 22, 2005 | 04:36 PM
Steve Guttu's Avatar
TPI setup question
I've checked threads for the answer to my question and couldnt find it. I was wondering if someone could help me out. I have a 86 305 TPI and I want to install it on a 91 350. What do I need to do to make this setup work. I've heard all I have to do is change the chip and install ajustable fuel pressure regulator. Is this all???? Thanks!!!
Old Feb 22, 2005 | 04:48 PM
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
You will also have to have a base manifold that has the correct angle bolt holes for the later style heads. The two center ones changed on the later heads.
gta90
Sep 15, 2015 04:00 PM
masonta
Aug 31, 2015 10:14 PM
redmaroz
Aug 16, 2015 11:40 PM
Sanjay
Aug 12, 2015 03:41 PM
squiggy2
Aug 9, 2015 09:30 PM
