would this work for my car?
Old Mar 3, 2005 | 02:23 PM
BulliTooth's Avatar
Car: 1989 Formula
Axle/Gears: 9 bolt GW6
i might score an air intake for a good price. its from slp for camaro/firebird 90-92 air intake but i have a 89 firebird, slp also makes them for 89's slp intake well would the 90-92 fit my motor? there both for L98's right?
Old Mar 3, 2005 | 03:13 PM
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
I think the only difference will be the 90-92 will not have provisions for the MAF. If that is the case, you would have to modify it somewhat to fit the sensor in your application.
Old Mar 4, 2005 | 08:11 AM
BulliTooth's Avatar
Car: 1989 Formula
MAF
would there b a problem if i tossed the maf?
Old Mar 4, 2005 | 09:47 AM
Chrome's Avatar
Car: 92' RS Camaro
Yep, you'd make your car a boat anchor.
But if you really want to ditch it you can switch over to SD. Several ppl on this site have done that.
Old Mar 4, 2005 | 11:26 AM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
SLP only made the runners. If this is what you are talking about they will work just fine. Allen
Old Mar 4, 2005 | 02:21 PM
BulliTooth's Avatar
Car: 1989 Formula
ima noobie....SD?
Old Mar 5, 2005 | 07:43 AM
406TPI's Avatar
Car: 1985 IROC-Z
Originally posted by BulliTooth
ima noobie....SD?
SD= speed density
MAF= Mass Air Flow
You cannot just ditch the MAF in your application as stated above. The ECM needs that sensor to know what the density of the incoming air is in order to make the proper fueling calculations. You can switch out to a later style ECM that uses speed density with a MAP sensor (Manifold Absolute Pressure) but this involves not only swapping out ECM's but also a wiring harness. You can re-pin your wiring harness to retrofit, but it is not something I would recommend for somebody who does not feel comfortable with looking at wiring diagrams.
specialized
Jun 18, 2022 09:26 AM
Terrell351
Jun 13, 2021 01:13 PM
TheExaminer
Aug 26, 2015 04:59 PM
jharrison5
Aug 19, 2015 05:53 PM
