vortec head torque specs??
Old Mar 4, 2005 | 04:03 PM
billyhoss's Avatar
hi iam about to install a set of vortec 906 heads on my motor with the Scoggin Dickey base but can not find out how much to torque the intake bolts? i have read anyweres from 11 lbs to 35lbs on the site, does anyone know fore sure what to torque them at? would help me out alot, thanx in advance oh iam also using the fel pro 1255 intake gasket and not the factory plastic ones.
Old Mar 4, 2005 | 05:18 PM
meangene83's Avatar
Car: 91 formula
Engine: 355
11 lbs is the factory spec
Old Mar 4, 2005 | 06:01 PM
billyhoss's Avatar
so iam guessing that would be using the plastic gaskets, anyone know about the fel pro 1255 ones? thanx again
Old Mar 5, 2005 | 11:12 PM
Black 91 Z28's Avatar
Car: 1991 Camaro Z28
I torqued mine to 18 ft lb and haven't had any leaks.
Old Mar 7, 2005 | 12:55 PM
92blackZ's Avatar
Car: 1992 Z28 camaro
Engine: 5.7
Cylinder heads and SD base
Black 91 Z28, I have been thinking of using the SD base and Vortec cylinder heads. How much would that help a bone stock 1992 Z28, L98? My car currently runs 14.60's at high 90's mph? I have the 323 gears, Borla cat-back and K-N filters in the stock air housing. Thanks
Old Mar 7, 2005 | 02:04 PM
I seem to have bad luck at the track so I'm probably not the one to ask but, there was a definate improvement going to the Vortec setup. It pulled harder in the upper RPM and doesn't feel like there is such a wall at 4500 RPM. I'm hoping to get to the track next week so I'll see if I can make any improvements.
Look up some info on Dyno Don (I think that's who it is) he's got a Vortec setup and runs in the 12s.
Old Mar 7, 2005 | 02:14 PM
92blackZ's Avatar
Engine: 5.7
SD base and Vortec heads
Thanks Black 91 Z28, keep me posted on your progress.
84z96L31vortec
Aug 20, 2017 12:16 AM
Tinbender59
Mar 17, 2017 10:50 AM
earlpote
Aug 28, 2015 10:42 AM
L98GTA87
Aug 11, 2015 06:55 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
