stealth ram
Old Mar 6, 2005 | 08:31 PM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Transmission: MN12 6speed
Axle/Gears: 3:42
stealth ram
im not to familiar wut u have to do swapin to a holley stealth ram setup. i have a 87 iroc tpi and im planin to do the changeover im interested in it but i heard that i have to do several modifications dealin with the computer and ?9 injector? so wut escatly do i have to do or is it possible?
Old Mar 6, 2005 | 08:40 PM
rsn932's Avatar
you do not absolutely need a new chip for it to work but a chip will drastically help performance. i thought that mine wouldnt start without the cold start injector, but it did and i havent had any problems with it not starting even in 20 degree weather. the only things that you really have to do are connect the stock fuel lines to the fuel rails and get a new thermostat housing that points in the right direction. do a search and you will find plenty of information on what you need to install the HSR and check out www.stealthram.com
Linson
Oct 24, 2025 02:00 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
L98GTA87
Oct 19, 2015 10:43 PM
mfp189
Sep 27, 2015 09:25 AM
R3500
Sep 8, 2015 10:12 PM
