will an lt1 intake work ?
Old Mar 6, 2005 | 09:08 PM
j88l98irocz's Avatar
Car: 88 IROC-Z twin turbo
Engine: forged 383 8-1 compression
Transmission: t56
Axle/Gears: 9in 3.50's trac loc moser axles
can I use a lt1 intake on a stock 350 tpi without changing the cam or heads and still get a gain in performance out of it or would i be better off using the edelbrock base and high flow runners ?
Old Mar 6, 2005 | 09:33 PM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
The LT1 intake will only fit if you convert it to a standard SBC bolt pattern, drill a distributor hole, add a hold down clamp and boss, and add coolant ports because the LT1 does not have a coolant neck for the upper radiator hose. You will also need a remote thermostat and a few other things.
Old Mar 6, 2005 | 09:57 PM
Transmission: t56
I have the remachined intake with the distributor hole l98 bolt pattern and remote t stat
Old Mar 7, 2005 | 07:58 AM
Chrome's Avatar
Car: 92' RS Camaro
Ehhhh, I'm not sure you'd see much of a gain. You'll gain alittle on the top end, but I'm afraid that the loss in torque you'll have will not be offset by the minimal (small cam) gain on the topend.
At least put like a ZZ4, or Hot Cam in it. The ZZ4 cams can be had on Ebay for like $130.
Although you might have to have the valve guides machined and springs/studs. You can do the Studs yourself with a Mr Gasket kit ($30). Springs 981 ~ $50. And machine shop labor ~ $40 for machining guides.
I think then you would have a fun little combo.
Then you will have made your heads the limiting factor in hp, not your cam/intake. Next purchase would be a good set of heads to let that 350 LT1 breath.
Old Mar 7, 2005 | 07:14 PM
89Formula5.7's Avatar
Car: 89 Formula 350
Engine: L98 w/ Stealthram
Axle/Gears: 9 bolt 3.27
My car feels a lot more responsve now. I think that it's a great swap. There's a lot more info here
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
sreZ28
Aug 14, 2015 07:48 PM
Thirim
Aug 9, 2015 06:19 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
