LT1 Block Only Question
Old Mar 12, 2005 | 12:17 PM
BaggedDropTop's Avatar
Car: 1991 Z-28 Covertible
Engine: Stock
Transmission: 5-spd
Hey guys i have a question, their is a guy selling a 96 Z-28 LT1 Motor with 78K for 500 bucks. The only thing is that the Intake is not their. SO i was wondering what would be the result if i put my TPI injection on top of the lt1 block. Would it be a good idea to get better TPI heads. Any thoughts? thanks
Old Mar 12, 2005 | 12:45 PM
Vader's Avatar
1. You would have leaks;
2. No such thing as "TPI heads" that are "better" than LT1 heads;
3. Thoughts? Oh, yeah. Get the engine, PCM, and wiring harness if you can. Port up the LT1 heads, then get a used LT1 intake (under $200). You can use the L99 intake as well, which is what makes them so cheap. Adapt away, and you'll have something.
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
sreZ28
Aug 14, 2015 07:48 PM
