Fuel Lines
Old Mar 13, 2005 | 09:23 AM
TKO500's Avatar
Car: 91 B4C, 17 C7 GS, 16 Denali DMax
Engine: LS3, LS3, LML
Axle/Gears: 3.23, 3.42, 3.23
Fuel Lines
I am just about to begin swapping a TPI into my RS. Do the fuel lines need to be replaced due to the higher pressure needed to feed the TPI?
Has anyone successfully done this conversion leaving the stock fuel lines in there?
Old Mar 13, 2005 | 03:49 PM
1320 Right Ln.'s Avatar
if u've got a 92 RS, then the stock motor should be fuel injected regardless of V6 or V8. therefore your stock fuel lines should be for high-pressure fuel injection. Assuming that u've somehow got a carb'd motor in there, the fuel lines running to and from the tank should still be hard lines anyway.
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
