What injectors for a 383
Old Mar 14, 2005 | 10:25 PM
YenkoST's Avatar
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
Hey guys;
Just curious as to what injectors ya'll are running with 383's. I need 30 lb injectors to go with my 383 9.5 compression 180cc AFR heads and a Hot cam on top of a HSR system. Thanks.
Old Mar 15, 2005 | 02:05 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
I have been running 24 # ford motorsports injectors in my 10.5:1 383. I will also be running the same injector in the new 406.
Old Mar 15, 2005 | 03:22 PM
1320 Right Ln.'s Avatar
Re: What injectors for a 383
Originally posted by YenkoST
Hey guys;
My motor is almost the same as yours, 383 - 30# injectors - 9.7:1 comp - 195cc trickflows - 214/220 cam - HSR manifold.
Old Mar 15, 2005 | 07:40 PM
IRACE87's Avatar
Car: 1987 IROC-Z
Engine: 383 HSR, AFR 190
30 lb injectors is what I suggest.
With my 383, 190 AFR, HSR, 10.4:1, and a good cam I see around 80% Duty Cycle at 6000 rpm with an AFR of around 12.5.
So if I one day I make more HP I will have to upgrade to 36 lb.
PAT
Old Mar 15, 2005 | 08:23 PM
YenkoST's Avatar
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
What brand are ya'll using on the 30 lbs injectors?
Old Mar 15, 2005 | 10:02 PM
Venom
Old Mar 15, 2005 | 10:07 PM
IRACE87's Avatar
Car: 1987 IROC-Z
Ford....
Old Mar 15, 2005 | 11:38 PM
YenkoST's Avatar
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
Well.....I don't know what are the best injectors to buy for my engine honestly so...I hate to put Fords on a Chevy engine but if they are the best then I reckon I will. Thanks for the input guys.
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
earlpote
Sep 12, 2015 11:55 AM
Keiffer76
Sep 9, 2015 08:52 PM
