Corvette TPI VS Firebird TPI 88-96
Old Mar 15, 2005 | 08:13 PM
BlackRob91's Avatar
Car: 1991 FireBird Formula
Engine: 355 TPI
Transmission: 5 Speed Manual
What is the main differences between these 2 TPI motors is the vette motor better than the firebirds in these years. And does the ZR1 have the TPI set up or LT1. what years did they start the LT1 in the Vette?
Old Mar 15, 2005 | 08:17 PM
3.1EyeCandy's Avatar
Car: 1987 GTA
Transmission: 4L60e
Well, to begin the vette had alluminum heads with D-shaped exhaust ports. I believe they also had a slightly more aggressive cam (could be wrong) and the solenoid in the transmission was different. Because of the different heads, the chip was slightly more agressive as well.
Not too sure bout the ZR1 - if memory serves me correctly it used an LT5. In 1992, the corvette used the LT1
Old Mar 15, 2005 | 10:08 PM
formula2fast's Avatar
Car: 87 Pontiac Firebird Formula
Engine: 355 SBC-Thats all I can say or they will break my legs.
The ZR1 (LT5) was a totally different engine. It was a joint venture between GM and Lotus. It was an all aluminum DOHC engine (4 cams) had 16 injectors, and no common engine parts with a SBC. Totally different engine, and extremely expensive. The long blocks went for $24,000 from GM. Not worth it for the 405hp they made. THat is why they stopped making the ZR1
toronto formula
Nov 10, 2015 06:17 AM
masonta
Aug 31, 2015 10:14 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
