A little Problem with my 5.0 TPI
Old Mar 16, 2005 | 07:05 PM
Silver_IROC_87's Avatar
i have a 1986 IROC-Z with a 305 TPI. well, when i start it up it runs really rough and stalls. but after givving it gas to warm up it runs better. then lately its just stopped running. it cranks and cranks and only sputters once and a while. the intake smells like gas when i remove the duct. what type of things should i check for?? The fuel pump comes on. it cranks. theres air getting to it. i know that theres a problem with the MAF sensor. but it ran before???
Old Mar 16, 2005 | 08:16 PM
SLP IROC-Z's Avatar
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
bad maf most likely, unplug it and see what happens, if the car runs good then theres your problem.
Old Mar 16, 2005 | 08:41 PM
tried what you said and still no start. its like its not firing
Old Mar 17, 2005 | 04:04 PM
IROC212's Avatar
Car: 1986 IROC
Engine: 355 Tpi
Axle/Gears: 9 Bolt 3.27
Does it have spark? My 86 started acting up intt. turned out the coil was toast. The opening in the center of the coil (where the spring off the carbon button contacts) was all distorted. May be simple ign prob.
Grant2k
Jul 10, 2018 04:01 PM
jbd1969
Aug 17, 2015 07:06 PM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
