3.73's wt my combo, should I??
Old Mar 18, 2005 | 12:46 PM
91wtROH17's's Avatar
Car: 91Z
Engine: 355/afr/sr/lpe219
Transmission: built 700R
I want to go with some 3.73's this year, does anyone think they will just slow the car down in the 1/4?? I am gonna port the crap out of the Super ram eventually!! I know a couple guys in here might be able to help me. My converter stall speed is about 2600 if that helps. I have searched, but it looks like some have good luck with the gearing, and some wont touch anything over 3.42?? HELP ME!!
Old Mar 18, 2005 | 02:29 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Your sig says you have a 2.3 60 w/no traction....gonna be even tougher to hook'em up with 3.73's...
I'd suggest you head to the suspension forum and do some homework on how to get it to hook up...seems you have 12's within a reasonable range...long before you think about re-gearing it
Old Mar 18, 2005 | 07:27 PM
GTA matt's Avatar
Car: 1990 GTA/1989 Iroc
Engine: L98/383
Transmission: 700r4/t56 magnum
Axle/Gears: 9"
The 3.73's won't hurt your combo. They helped mine and I still have the stock runners and such. However, traction WILL be a problem. Before doing the gear swap I recommend an adjustable torque arm, LCA's and relocation brackets, 90/10's, and of course drag radials or slicks. Then you should have no problems hooking.
Old Mar 18, 2005 | 07:52 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
3.73 gears gained me 3mph in the 1/4 while dropping my ET down half a second. I had 3.23 gears originally.
One of my friends with an 86 Z28 has a 355 with an HSR and 3.73 gears and his car runs great, still pulls past 140mph and gets decent gas milage.
Linson
Oct 24, 2025 02:00 PM
InfernalVortex
Apr 20, 2021 11:31 AM
JSDaddy189
Sep 26, 2015 03:50 PM
roysatikas
Sep 22, 2015 08:15 PM
whyt86roc
Sep 10, 2015 10:03 PM
