What size injectors for this setup? What about my pump?
Old Mar 18, 2005 | 06:44 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Do I need the 24# or the 30# for this setup:
350
Holley Stealth Ram
Trick Flow heads
Then, will the stock fuel pump be up to the task? It's a brand new pump, sending unit, tank, and all the lines. Cost me over a grand just for that!!
Old Mar 18, 2005 | 08:04 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
Your question is a bit vague to answer properly. What hp do you hope to make? Nos or no? What rpm will the motor rev to? Give all the info you can and you will get plenty of replies.
Old Mar 18, 2005 | 08:18 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
I want to make the most HP I can!
I will have Nitrous, but it's not like I'll be using it all the time, so not sure if it's a real factor or not.
Supposedly my setup will be a high revving motor, but I'm affraid of revving any V8 over 5000RPM
Also, do larger injectors always flow more, or what? I mean, if I only need the 24pph, and I get 30, will it choke it or anything?
Old Mar 19, 2005 | 07:47 AM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Axle/Gears: 3:55
If your nos kit is wet then injector does not have to be increased to compensate. If you are using the ford motorsport 24# and you are reving below 6k you will be fine. I have the 24# fords in my 383 and it is too much injector for my car. I assume from your sig that you have a mass air car. This is helpful if you are running stock programming. My car has a similar combo. I have run 12.0's on motor and high 10's on spay using 24# ers and stock replacement pump.
Old Mar 19, 2005 | 07:55 AM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Whew! I didn't want to drop the tank again!
This is the NOS setup:
NOS 05151 TPI wet plate system
NOS purge kit
Old Mar 19, 2005 | 06:30 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Axle/Gears: 3:55
I have the same 5151 kit. Although I ran the stock pump with good results, I have since added an aux pump for insurance purposes. You may want to do the same when the budget permits.
toronto formula
Nov 10, 2015 06:17 AM
69 Six Pack
Oct 5, 2015 07:51 PM
gta90
Sep 15, 2015 04:00 PM
kyleb24
Aug 15, 2015 08:24 AM
knight72
Aug 10, 2015 09:32 PM
