carb to TPI change over
Old Mar 19, 2005 | 04:01 PM
xandersdad's Avatar
Car: Now Camaorless
I have a 1986 IROZ Z 305 with a computer controlled quadrajet. I have a 1986 TPI 305 parts car complete. I'm thinking of taking the TPI set up and replacing the quadrajet with it. Would this be worth the effort? Would I have to change the entire wire harness and computer? I have everything, TPI, harness, fuel tank with pump, computer. All I got to get is a distributor. I'm not going to do it right now but it is a possibility later on this summer. I would like some comments.also the quad has a factory t-5 the TPI car has a 700r4 if this makes a difference
Old Mar 19, 2005 | 09:28 PM
tilstad's Avatar
Car: 87 Black Formula
Engine: Rollercammed Lg4
Axle/Gears: 3.23 10 Bolt Locker
there are some answers here
Old Mar 20, 2005 | 12:28 AM
VincentZ28's Avatar
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
My 86 Z28 was the same as yours. I had a doner TPI 85 Z28. It took about 3 weeks because I had to work on my regular job. But I swap everything including the fuel lines, rear disc brakes, T5 trans, rewired for the A/C and pull down hatch, engine, music, power door locks, rear defogger, cruise control, interior, 2in drop springs, dash board with the wire harness still attached, all the wires in the engine compartment and all the suspension parts. Yes it was a lot of work.
midge54
Dec 27, 2019 04:14 PM
Infested
May 22, 2018 11:56 PM
gta90
Sep 15, 2015 04:00 PM
86IROC112
Aug 17, 2015 02:00 PM
Sanjay
Aug 12, 2015 03:41 PM
