Firing order problems
Old Mar 20, 2005 | 11:01 AM
ace16a's Avatar
Car: 1985 Z28 Camaro
Engine: 5.0 TPI
Transmission: 700R-4
Axle/Gears: Posi Richmond 3.73
Hey everyone, I just put a new cap, rotor and accel hei super coil on my 1985 Z28 305 TPI. now the engine doesn't idle right and back fires when i give it any gas. i'm almost positive that i crossed a couple of wires. can anyone give me a diagram of the firing order?
Old Mar 20, 2005 | 11:18 AM
Vader's Avatar
Old Mar 20, 2005 | 11:22 AM
ace16a's Avatar
Engine: 5.0 TPI
I (and my car) thank you vader.
Old Mar 22, 2005 | 01:35 PM
strider681's Avatar
Car: '87 Pontiac Trans Am GTA
Engine: 350 5.7L TPI (L98)
do i have my distributor backwards or somethin cuz when i use this firing order no start.. if i use exactly opposite car starts and runs fine...
Old Mar 22, 2005 | 02:57 PM
ace16a's Avatar
Engine: 5.0 TPI
You probably do. my car works just fine with this firing order. do you have a hei coil?
Old Mar 22, 2005 | 03:16 PM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
You don't have to pay attention to where the #1 is in the diagram, #1 can be anywhere on the cap provided the rotor is pointing to the terminal you are using as #1 when the #1 cylinder is at TDC on the compression stroke. The important thing is the Firing ORDER: 1-8-4-3-6-5-7-2
Old Mar 22, 2005 | 05:19 PM
strider681's Avatar
yes I am using a stock HEI coil.. and I have the firing order right but my car has to turn over about 5 sec or so to start.. checked timing is @ 6 BTDC.. mine may be a fuel issue..
Old Mar 22, 2005 | 06:00 PM
78camaroz28's Avatar
Car: 2001 Trans Am WS6
Ironic...
ace, I have a question for you. Where is your rotor pointing when the engine is at TDC? My 86 T/A 305 TPI has the rotor pointing at the left intake runner...and from what I'm used to with SBCs, that ain't right. But it runs, what the hey...
Old Mar 22, 2005 | 06:05 PM
I just re-read vernw's post and realize that this is true...but typically doesn't the rotor point more toward what's dipicted in the diagram on Vader's post when its "more correct"?
My 78 Camaro is exactly that and so has every other SBC I've ever worked on....
Old Mar 22, 2005 | 09:01 PM
ace16a's Avatar
Engine: 5.0 TPI
If I remember right, the rotor is pointing just before the no. 1 point in the dist. My car runs perfect. It starts up almost as fast as can turn the key.
Old Mar 23, 2005 | 11:36 PM
Mine starts and runs fine as well (for the most part...the engine is brand new....0.7 miles on it since breaking in the cam).
This is giving me a headache...to hell with it...the distributor stays where it is.
Old Mar 24, 2005 | 07:31 AM
ace16a's Avatar
Engine: 5.0 TPI
If it's not broke, don't fix it.
Old Mar 24, 2005 | 01:28 PM
vernw's Avatar
EXACTLY!!!!
Old Mar 26, 2005 | 07:50 PM
iroc_3030's Avatar
Car: 1988 camaro irocz
Engine: 350 tpi
if you have the plugs wires on right and you have checked the cap and rotor bug that they are right what else could cause an engine to mis fire like that and back fire through the exhuast i just chaged my wires and plugs and my 350 is not wanting to start at all. before that when it would get hot it would miss when you started it up again and sometimes be a little hard to get started. what causes this
Old Mar 28, 2005 | 11:22 AM
dyeager535's Avatar
Car: Which one?
Engine: 355
Transmission: 465
Originally posted by 78camaroz28
Ibut typically doesn't the rotor point more toward what's dipicted in the diagram on Vader's post when its "more correct"?
The reason to do it like the diagram (and factory did) is simplicity when working on it.
If you end up with #1 being somewhere else than what the diagram shows, if you are incapable of tracing the plug wires, you'd really have no clue where the wires are supposed to be on the cap. If you pulled them off the cap without verifying which wire is which, you'd cause more work, and end up scratching your head for a bit.
Just like changing the color of wires in a wiring harness from stock...it doesn't hurt anything, except when someone unfamiliar with your "mods" has to deal with it.
92camaroJoe
Jul 29, 2023 07:57 PM
Street Lethal
Apr 30, 2019 12:14 PM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Fronzizzle
Aug 9, 2015 01:15 PM
