type of runners
Old Mar 20, 2005 | 08:44 PM
TexasB4C's Avatar
Car: 92 Camaro B4C 350
type of runners
what type of runners are these, are they stock because i thought the stock ones could be siamesed?
if not then which ones were shown in the tech section's article on siamesing runners?
Old Mar 20, 2005 | 08:54 PM
GTA matt's Avatar
Car: 1990 GTA/1989 Iroc
Engine: L98/383
Transmission: 700r4/t56 magnum
Axle/Gears: 9"
sorry, i got the red "X" of death
Old Mar 20, 2005 | 09:04 PM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
Usually people talk about siamesing the stock manifold base, not the runners. Stock runners are separate extruded tubes, one for each cylinder. They are super thin. In order to siamese stock runners, you cut half away from each opposing runner and tig weld in more sheet aluminum. It's not something most people could do. I have a mig set up for aluminum and was thinking about trying it, but I am probably going to spring for a set of aftermarket runners and an aftermarket base instead. Siamesed stock runners look disgusting unless someone does an amazing job welding and then grinds and polishes them.
Old Mar 20, 2005 | 09:35 PM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
those look to be OEM runners.the picture below is what they look like once you connected the tubes.
Old Mar 20, 2005 | 10:08 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
Those are stock, the article you are referring to in the tech section are SLP runners.
Linson
Oct 24, 2025 02:00 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Rocket-Doc
Nov 14, 2015 02:08 PM
bjpotter
Oct 4, 2015 07:48 PM
Royal_Z
Sep 30, 2015 08:45 PM
