HSR or SDPP
Old Mar 20, 2005 | 11:10 PM
walterrao's Avatar
Car: 91 RS
Engine: vortec 355 hsr
Transmission: wct5
Axle/Gears: bg3.27
HSR or SDPP
Im soon to be dooing a TPI swap and am curious what you guys have to say. I am running vortec heads with an lt1 cam 205 intake and 207 exaust. on a 9.7:1 comp 355. I am leaning towards the HSR, but I am not sure if i have enough cam for it. I would really appretiat any feedback,
Walter
Old Mar 21, 2005 | 06:55 PM
walterrao's Avatar
Car: 91 RS
Transmission: wct5
Axle/Gears: bg3.27
the stealth ram and the scogin dickey base are close to the same price. sorry if this topic comes up too often or somthing but i am curious.
Old Mar 21, 2005 | 07:40 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
the 450" 460" lift isnt much for a HSR IMO. If i had the cam already i would og with the sdpc.
Do you want low end or upper?
Alittle more info?
Old Mar 21, 2005 | 10:30 PM
walterrao's Avatar
Car: 91 RS
Transmission: wct5
Axle/Gears: bg3.27
well i want to be able to make power to at least 5500 and possibly close to 6000. I also still want to have enough torque at around 2200 to 2500 to be able to cruise the freeways in the Appalations b/t TN and PA(alot of elevation change and curves). the cam and heads are already installed im just wanting to swap from tbi to port fuel injection. I heard that the original tpi intake and runners will hit a wall at 4500 and i dont really want this. Also i may do a cam swap sometime in the future, i just dont have the money to get the heads machined right know.
Old Mar 22, 2005 | 04:51 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
Sound like you really need the Sddpc intake. If you can afford it, the best money will be spent putting some runners inbetween the "ported plenum" and the vortec base.
The cam you have will feed the vortec heads a good amout of tq.
Plus staying with a LTR setup will benefit the performance of the heads.
Old Mar 23, 2005 | 01:03 PM
Parrydise7's Avatar
Keep in mind that the HSR is not smog legal.
86z89iroc
Oct 5, 2015 01:04 PM
86CamaroDan
Sep 29, 2015 10:08 PM
mike22115
Sep 28, 2015 04:49 AM
BBSDesigns
Sep 22, 2015 03:08 PM
355tpipickup
Sep 4, 2015 05:32 PM
