TPI Performance
Old Mar 24, 2005 | 04:06 AM
92PrpleCamaroRS's Avatar
Car: 1992 Camaro RS
Transmission: T5 Transmission
Axle/Gears: 10 bolt 277 posi rear end
TPI Performance
Ok, I have this 350 Long Block I am about to put into my 1992 Camaro RS, the block is from a guy I know, its only got like 12k miles on it and he told me it produces 305hp and 405tq, he is good to his word, so i can trust him, but i am adding a stock TPI intake to the top of it off a 1987 IROC Z, the car was originally a 305 TBI, so i had to get the wiring harness for it too, but my question is how much horsepower will i gain with the TPI intake and I am putting headers with 3'' exhaust with cat and 40 series flowmaster muffler, that being the only mods I am doing to it right now. And if i add a 58mm throttle body some new runners and fuel injectors along with ignition and intake with the computer chip, how much horspower do u think i will produce, if there is anyone that can help me out, or give me some tips that would be nice, thanks
Old Mar 24, 2005 | 05:48 AM
92'Sleeper's Avatar
Car: 92' B4C Camaro
Transmission: G-Force T5
From what I've read on here, I think the 58mm trottle body will be an over kill. I seen many threads that say the stock 48mm is good up to around the mid 300's, maybe a little higher. That being said, I would go with a 52mm if you plan on being around that HP or higher in the futuer.
Old Mar 24, 2005 | 12:23 PM
Chrome's Avatar
Car: 92' RS Camaro
You'll prolly only see topside of 260-265hp with the STOCK TPI.
Don't waste your time w/ the 58mm Throttle body. The TPI is very restrictive. Spend that money on upgraded base/runners.
Port your plenum.
Throw away the 882's
Current injectors are OK.
Gut your airbox (Free!!)
Exhaust is great idea (w/ headers).
And the best free most important idea to give you is...
Old Mar 24, 2005 | 06:14 PM
Car: 1992 Camaro RS
so what if i upgraded runners and throttle body to like a 52mm and then port out the plenum and stuff, i am just looking for horsepower upgrade, so do u think that will help out
gta90
Sep 15, 2015 04:00 PM
NBrehm
Aug 25, 2015 11:49 PM
theurge
Aug 21, 2015 12:46 PM
1989formula5.7l
Aug 15, 2015 11:35 AM
Sanjay
Aug 12, 2015 03:41 PM
