Who's running zz4/tpi/vortec or other head?
Old Mar 25, 2005 | 10:04 AM
irocdaddy's Avatar
Car: 89 iroc,2012 eco 150,roadglide
Engine: zz4
Transmission: t56
I am thinking of going with a different head on my zz4. what is everyone else running" i do not want to switch my cam, just the heads. what will get me to 400 h.p. in the head dept. i also want to run 87 octane instead of prem. let me know your combo.
1.6 rockers and vortecs?
Old Mar 25, 2005 | 10:20 AM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Axle/Gears: 7.5 / 3.42's
I'll be using AFR 180's (if they ever get here) with the zz4/tpi. I think that would be your best bet, but 400hp? Meh....
Old Mar 25, 2005 | 11:04 AM
irocdaddy's Avatar
Engine: zz4
Transmission: t56
who makes afr 180's? what compression?
Old Mar 25, 2005 | 05:09 PM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
www.airflowresearch.com makes them, you can get them in 68 and I believe 74cc chambers. With flat tops/4-valvereliefs and piston to head clearance of about .045 you should be somewhere between 9.75 and 10:1 (with 68cc chambers). www.tenperf.com seems to have the best prices....... but be warned, they are on a two month wait .
Old Mar 25, 2005 | 08:59 PM
vladicore's Avatar
Car: 67 camaro ( project )
Engine: 6.7 408 n a snail
Transmission: 4l80 - stalled
Axle/Gears: 3.25 - narrowd tci kit 9 inch
isnt the zz4 10.0 1 compression w/ a 64cc head. im almost positive it is. so going to a 68 you will lose a few comp points probly be @ 9.7 ?.and i dont think just putting afr heads will get you 400 hp. youll need aftermarket runners, plenum( port it ) and a 52 mm tb to get close to 400. also the zz4 cam is kinda weak, there are far better cams out there. especially if you are taking the heads off anyways your more then 9/10's there. but its just my .02$
i know my dads zz4 ran like hammered sh*t. its advetized 355hp and 405 torque had to be an overestimate. we took it apart and had the heads shaved and ported the intake , after that i believe it had the posted numbers.
Old Mar 26, 2005 | 03:19 AM
smokefan's Avatar
Car: 86 IROC w/Danko bodykit, 1988 iroc vert, 1989 k1500 pickup 6" lift and 35" tires, 2002 chevy tahoe z71
Engine: 383 stealth ram, 305 tpi, 350 tbi, 5.3l
Transmission: T56, 700r4, 700r4, 4l460
go with the afr heads. they kick ***. just hope you dont wait as longf as i had to..about three and a half mounths for them. you should look into bigger runners....also why not look into holleys stealth ram.
Old Mar 26, 2005 | 06:56 AM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Whats the piton to head clearance on a zz4 crate engine?
Frozer!!!
Jan 19, 2024 04:55 PM
Jake_92RS
Jan 28, 2020 10:37 PM
midge54
Dec 27, 2019 04:14 PM
theshackle
Mar 5, 2017 06:37 PM
86IROC112
Aug 17, 2015 02:00 PM
