Stock 91 ecm & better heads
Old Mar 26, 2005 | 04:30 PM
finnbird's Avatar
Car: Pontiac Firebird -91
Engine: 5.7tpi
Transmission: th700
Hello. I am reconditioning my stock 91 Firebird Formula 350tpi cylinder heads (1.94 &1.5) .
My plan is : new 2.02 & 1.6 valves, complete professional head work with pocket porting, Edel tes headers.
Will better flowing heads work with stock 90-92 Map/Speed density system?
My Budget doesn´t allow custom proms or aftermarket dfis right
now.
Am i asking for trouble :running lean at higher rpm,rough idle ?
Should i just rebuild my heads with stock valves?
Old Mar 26, 2005 | 05:19 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
With SD cars, you need to have the eprom reprogrammed to get the most out of your mods. In fact, even a bone stock L98 will benefit from reprogramming the eprom.
I would not waste my time on a "custom" eprom. I would get the equipment and learn to burn your own eproms. It's a lot easier than you think and the cost does not need to be expensive either.
Old Mar 26, 2005 | 05:20 PM
Car: Death Mobile
Engine: 666 c.i.
Oh yeah, IF you did nothing to the eprom, it would probalby run reasonably well. It's cam changes that causes the most problems.
But, to get max performance; learn to burn your own eproms.
Old Mar 27, 2005 | 10:38 AM
finnbird's Avatar
Engine: 5.7tpi
Transmission: th700
Thank you for your reply.
sweet_87_iroc
Sep 25, 2015 10:01 PM
gta90
Sep 15, 2015 04:00 PM
camaro71633
Sep 1, 2015 10:24 AM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
marcusaw
Aug 10, 2015 08:13 AM
