Problem l98 350 mystery
Old Mar 31, 2005 | 08:46 PM
formula1988's Avatar
Car: 1988 forumla 350
Engine: l98 350 tpi
Transmission: 700r4 2100 stall
I was changing the oil pump on my 350 firebird. I took the starter off and a couple bolts broke, i think the were just to hold the starter up. So i had to get a new cillinoid*.but i never replaced one of the bolts. I also had to raise the engine to get the oil pan off. well, i got everything put back on and went to start it and there was nothing. The interior lights would not evn come on when i turned the key half way. My lights came on fine and the interior lights came on when i turned the lights on. There were 6 wires that hooked to the cillinoid* four big one and 2 little ones. I put the bigs one on the bigger bolt and the smaller wires all on the smaller bolt. I thaught i did it right, but maybe not. i am very confused, and i would be greatful for any help. ".but i never replaced one of the bolts." Could one of those bolts be a ground? Could i have hooked the started up wrong?
Old Mar 31, 2005 | 11:01 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
I'm trying to figure out if I should believe this post, but I'll give you the benefit of the doubt...
You wired something on the solenoid wrong. Probably fried the fusible link who knows, maybe the solenoid as well), and you'll destroy your starter if it's in there with one bolt only when you crank the motor over.
lt500r55
Sep 1, 2021 01:30 PM
Vintageracer
Jan 10, 2020 05:33 PM
Infested
May 22, 2018 11:56 PM
TheExaminer
Aug 19, 2015 10:07 PM
matthew911
Aug 12, 2015 09:38 AM
