Just installed BBK! But throttle dosent Hookup
Old Apr 2, 2005 | 04:10 AM
moneyman380's Avatar
Car: 1991 Z28
Installed 58mm BBK and the throttle does not hook up like the stock one does. Just wondering if this is a common problem and is there a adapter?
Old Apr 2, 2005 | 11:34 AM
Guest
Guest
Posts: n/a
There are 2 styles, 85-88 and 89-92. I bet you have the wrong one.
Old Apr 2, 2005 | 01:28 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
You most likely have the one for the 85-88 style throttle body. You will have to exchange it. Allen
Old Apr 2, 2005 | 07:36 PM
88tatpi's Avatar
Car: Z28HO/TA/Alfa Romeo
Engine: 305-350-502
Transmission: 700R4-5speed
BBK 58mm
The same thing happened to me but I had purchased a custom throttle linkage kit as I was doing an engine swap.
I wound-up getting the shift cable and throttle cable kits from
that famous company that starts with an L- Lock something (sorry I can't find the name!)
Other than the kits looked really sharp and I did get the optional billet cable holder to bolt onto the TPI manifold, the throttle kit had both new and old style connectors for my BBK 58mm. As my throttlebody came with part of the engine swap package (used) I could not exchange it, the kit "saved the bacon".
Good luck!
Old Apr 2, 2005 | 11:28 PM
Car: 1991 Z28
Is there any other differences, because i was just going to install a older throttle cable with the different connector. Will this work or am i just pissing in the wind?
Old Apr 3, 2005 | 07:30 PM
Pat Hall's Avatar
The company the one guy was trying to think of is called Lokar. They cater mainly to street rod type parts. If you want to go to the different style stock throttle cable, there's a guy on ebay who sells both styles brand new for about $23.00. He's also a member on this site. I think his user name here is 92blue. I know his name on ebay is tpi parts.
mdtoren
Aug 23, 2015 12:52 PM
Navy8125
Aug 22, 2015 07:13 PM
mdtoren
Aug 16, 2015 05:45 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
kyle5647
Aug 7, 2015 03:08 PM
