no readings in my temp. gauge
Car: Trans Am "GTA"
The problem Im having is that the dash temperature gauge is not moving. This happened fom one day to another, & Im affraid that if it is the temp sending unit the engine will overheat.
I got headders & changed a while ago to the jet temp sending unit.
has anyone heard of this before?
Re: no readings in my temp. gauge
Temp sender is generally in the driver side head between cyls 1 and 3. Fan switch is generally in the pax side head between cyls 6 and 8.
Former Sponsor
Car: 1992 Camaro RS
Engine: Yet another 350 TPI
Transmission: Borg Warner 6 spd
Its not your jet fan switch. Do as kevinc said, and check to sending unit which is on your driver side head. Either the wire fell off, or its bad.
I see, is not the same thing. so the fans should be working regardles of no reading, right?
I will check today.
I will check today.
Ghettobird52
Jul 5, 2024 11:18 PM
