Constant Miss. At a loss.
Old Apr 6, 2005 | 08:38 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
stock 89 350 TPI. New plugs, new wires, injectors are all at around 16-16.4 ohms, new cap rotor, coil, igition module, pick-up coil. WHAT ELSE WOULD CAUSE A MISS? I am so clueless. Motor has unkown mileage. It fires right up. idles silky smooth, never overheats, good oil pressure, no hesitation. But once you stat to drive it sounds like da da da da da like a miss. Sometimes it backfires as well when reved at ide;. If you get on it big time on the higway you can feel the miss then for 2 secs to clears up and a ton of power is there (You know your on 8 now) thn it'll go back to hesitation . Although the fuel injectors test ok, can they be bad interanlly?
Old Apr 7, 2005 | 02:27 PM
tyisfly0o0's Avatar
Car: 1988 camaro iroc-z
Engine: L98 5.7 tpi
Transmission: 700 r4
that happened to me and 1 of my spark plugs was rubbing agianst my exchaust manifold...so check it out
Old Apr 7, 2005 | 05:06 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
This has been a problem for the last two years so I have no idea. Plugs are all far away from headers.
skinny z
Carburetors
Sep 29, 2015 11:25 PM
Nighthawkf-117
Sep 24, 2015 02:47 PM
IROCThe5.7L
Sep 17, 2015 07:48 AM
Nick McCardle
Sep 10, 2015 08:36 PM
