corvette heads on a 383
Old Apr 11, 2005 | 06:24 PM
91305Z28's Avatar
Car: Camaro
i finally got my car painted and bought a 383 but i need some temporary heads, i currently have a 305 but i'm having to many problems and i don't want to invest money in the 305. will the corvette heads work on a 383 and where can i find them? i tried searching buy didn't find anything.
Old Apr 11, 2005 | 09:17 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
If you are referring to the 88-81 vette heads, the are the 113 castings. They are available used (usually) from www.comtemporarycorvette.com. They sell for 350-500 bucks. Last I checked the are available new from gm (complete) with zz4 valve springs for $850 or so a pair. New seems like the best bet unless you can score a good set (used) from a forum member or friend.
Old Apr 11, 2005 | 09:45 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
Are you referring to the Aluminum L98 Vette heads? IF so then yes they will work. Stock they will not be optimal, but they will not hurt the motor to run them. Ported would be better. They are the same as the ZZ4 heads also if you want to look for those...
Old Apr 12, 2005 | 12:22 PM
91305Z28's Avatar
Car: Camaro
ya i'm referring to the l98 aluminum vett heads and they will be ported if i can find them.
Old Apr 12, 2005 | 04:44 PM
ar91c4's Avatar
I got a sweet set of tricked out cast bowties for sale.PM me if your intrested.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
toronto formula
Nov 10, 2015 06:17 AM
gixxer92
Sep 1, 2015 04:32 PM
