running a 160* tstat with 730 ecm
Old Apr 15, 2005 | 01:43 PM
polygaryd's Avatar
Car: 1994 firebird
Engine: 427ci lsx bowtie block
Transmission: tremec t56 micro edged gears
Axle/Gears: Strange dana 60 with racing spool
hey guys i wanted some help with the idle vs coolant temp tables. since i put in a 160* tstat i turned my fans on lower and set my idle down from 120* up to 160* so it idles now at 650 rpms at 160* but it seems to be to low of an idle at any degree below 160 if that makes any sense. basically i wanted to know what your idle tables look like with a 730 ecm and a 160* t-stat so i can adjust mine to work well i am getting idle surging problems and even stalling untill it warms up then it is stable as hell.
Old Apr 15, 2005 | 03:59 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
Im not runny a 160* for now due to the weather. Its getting warmer so im fixing to change. Anyways i browse a bunch of different .bins just for curiosity and i was looking at the 730ramjetnosmog.bin and that looks like what you want.
But heres a good link to several .bins for you to choose from.
730 DIY-Binaries
Azrael91966669
25
Jun 20, 2017 04:04 AM
Jae992
Aug 27, 2015 09:07 AM
ezobens
Aug 19, 2015 10:29 PM
355tpipickup
Aug 19, 2015 10:02 PM
marcusaw
Aug 10, 2015 08:13 AM
