L98 Lifter question
Old Apr 17, 2005 | 10:31 PM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
L98 Lifter question
I don't know much about lifters, so this may be a simplistic (stupid) question but...
I'm looking to replace my stock 1989 L98 lifters soon.
They have vertical locking bars from the factory.
I spoke with a rep at Summit and he mentioned that I could take my existing vertical bars off and attach them to new lifters.
I was wondering if this is true and, if so, is it easy to do?
Any info would be greatly appreciated.
Thank you!
Old Apr 18, 2005 | 09:43 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Don't know about those vertical bars. The 89 should have factory standard roller lifters. They just drop into the lifter bores, a small plate slips over each pair of lifters, then the "spider" is bolted to the center of the engine to hold down the retaining plates. To replace the lifters all you need are the lifters, the rest can be reused. The pictured lifters would not be in a factory 89 engine:
Old Apr 23, 2005 | 12:49 AM
CAH383's Avatar
Car: 86 Camaro Z28
Engine: 5.3 LM7
Transmission: TH400
If they have the link bar on them they are not factory at all. Does the block have three posts in the middle with holes tapped in them?
Old Apr 24, 2005 | 08:00 AM
not sure... I don't have it apart rightnow. I'm just trying to get all the parts I need before I tear it down.
I believe the bar connecting the lifters was factory in 1989.
Old Apr 24, 2005 | 08:28 AM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Nope.
Old Apr 24, 2005 | 03:28 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
Never had the connecting bars . They had the above mentioned provisions in them to accept the standard roller lifter. Hense the name "Roller Block " . Which area bit cheaper than the ones with the link bars on them .
Old Apr 25, 2005 | 04:52 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
I think terminology is gettng crossed up.
What lifters are you actually looking at using?
The factory rollers have a locking bar/plate and can be used with another set of factory style lifters. This bar/dogbone/whatever slips over the lifters to keep each set from rotating...it doesn't actually connect to the lifter like the non-OEM style does.
Vintageracer
Jan 10, 2020 05:33 PM
Mickeyruder
Sep 2, 2015 02:45 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
Cameeeero
Aug 20, 2015 03:06 AM
redmaroz
Aug 16, 2015 11:40 PM
