L98 replacement heads
Old Apr 17, 2005 | 10:39 PM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
I'm still looking to replace my stock L98 heads with aftermarket ones.
I would like to keep all emissions and other factory hook-ups.
From what I've read, it seems that the Edelbrock heads have the heat passover, etc and are ready to bolt on. However, the flow numbers aren't the best (165cc intake).
Can anyone recommend a head that is ready to bolt-on out of the box (with no modifications) and still retains all the factory connections/ports.
FYI - I'm going to run a TPIS Big Mouth intake manifold.
I did do a search and it seems that the 2 popular ones are the Dart Iron Eagle & S/R heads. However, it seems that opinions are mixed and the Iron Eagle's don't have the heat passover.
Any info would be greatly appreciated.
Thank you!
Old Apr 18, 2005 | 07:39 AM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Axle/Gears: 7.5 / 3.42's
AFR 180's
Vintageracer
Jan 10, 2020 05:33 PM
CRFred
Feb 7, 2016 11:39 PM
gta90
Sep 15, 2015 04:00 PM
NBrehm
Aug 25, 2015 11:49 PM
anesthes
Aug 8, 2015 09:37 PM
