Hot start problem, advice?
Old Apr 19, 2005 | 03:49 PM
Brisk's Avatar
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
Ok I have an odd sort of problem, occassionaly, my car will not start once it is hot. I don't have a clue why. Its not a starter/solinoid problem because the starter will crank and the engine will faintly try to fire. It will catch and stumble for just a second and die. I could keep the key on cranking for 20 or 30 seconds and it will almost run, although very rough, but will die out as soon as I touch the gas. When cracking and depressing the gas, it will immediatly stop firing and just bog.
Oddly enough, this only happens once in a while when the car is hot (like after taking it out for a hard drive, or just simply moving it around in the yard on a very hot day) It does seem to be happening more frequently, and it has already left me stranded waiting for it to cool down.
Opening the hood and letting it cool down does seem to speed up the process so it will fire again. I've got no clue, any suggestions?
1988 Iroc 305 LB9 5-spd, cat back exhaust.. otherwise stock!
Old Apr 19, 2005 | 05:49 PM
ThirdGenFire's Avatar
Car: 2000 Trans Am and a 85 Iroc-Z
Engine: The Mighty LS1& 305 just beat meTPI
Transmission: 4L60E and 700R4
I have about the same problem but mine is a little worse. My car will start if it sits then after I drive it for a bit I turn it off and it will not turn back on, no click, no starter trying to fire just silence. Then I gotta just jump start it and it is fine. Weird world huh?
92camaroJoe
Jul 29, 2023 07:57 PM
theshackle
Mar 5, 2017 06:37 PM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
