Need some help!!!!!!
Car: 1991 Camaro Z28
Okay heres the thing, i was driving home from work today and half way home my car started to do something funny. As i stopped at a light and let off the gas the rpms dropped dramatically and the car almost died. So i keep goin and at the next light the same thing. Everytime i let off the gas the rpms drop just about to zero and the car wants to die. What the hell could be causing this. Service Engine Light is on and i tried to get the codes but i cant get crap the damn light blinks freakin quick and its weird. Anyone out there know what to do???
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
or an IAC, TPS, O2, or EGR that has gone out.... but pull the codes first!
turns out that the injectors were very clogged and needed cleaning. got them cleaned and stopped doing it. next problem is that now its idling extremely at about 15 rpms. gonna check the tps and check the voltage on it but dont knw what else it could be.
Car: 89 IrocZ
Engine: L98-ish
By 15rpms, do you mean erract at 1500?
I know you said you had the injectors cleaned, but from what you first posted on your problems sure sounded like a low battery and the car running of the alternator instead of 12v, I dunno, worth a check.
Car: 88GTAnotchbac/91 -Z/66 Chevelle
Engine: All strokers
Transmission: Pro built 700r4's
Thought it was some type of fuel problem..
Unhook the battery and allow the computer to clear any bad codes it may have recieved during your ordeal.
tried that already a couple of times but no change.....when i first start up the car in the mornings it idles good.......but when it gets to operating temp it idles high.........
Sounds like a vacuum leak, probably at the runner gaskets where they meet the upper plenum.
Usual procedure to diagnose is to spray carb cleaner at the junctions and see if the idle RPM increases temporarily.
yea i know i thought so to.....so i sprayed wd-40 over the plenum and no difference. Im really stumped and the guy that does my engine work doesnt have his diagnosis machine for another two weeks...
Well if you previously adjusted your idle in an attempt to get your ride to run better with out a scan tool then your IAC is probably out of tune.
