Lost a Vacuum hose I believe
Car: 1986 Iroc Z
Engine: Truck 305 /Bored .30 Flat Pistons/ Crane Cam
Transmission: Corvette 700R4
I am missing a vacuum hose and I was wondering if someone has
a more detailed vacuum diagram than the ones on this site.... its
still confusing which vacuums are on the top or bottom and
I cant seem to find where the windshield washer fluid vacuum
hooks up to.
hooks up to.
Car: 85Z28 87GTA 91GTA 98SS
Engine: SBC, LS-x
Transmission: T-5, 700-R4, T-56
windshield washer fluid vacuum? None of my cars have that. Tank to pump, then pump to nozles. No vac hook up at all.
You don't want to be sucking ww fluid into your intake.
TPI doesn't have that many vac lines. Which ones are you wondering about?
Car: 1986 Iroc Z
where does the windshieldwasher fluid hose run to?
It was running to the front right round vapor canister..
When I hook up all the lines that are supposed to go to the vapor canister like they show (in the diagram on the link at bottom of post) I have no where for the washer fluid hose to run to.. the hose runs from the top of the washer fluid too to where??
*Also wondering if the -U- shaped hose runs to the top or botoms on the canister?
Diagram of vacuum hoses...
https://www.thirdgen.org/techbb2/sho...threadid=97497
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Originally posted by IonNight.I have no where for the washer fluid hose to run to.. the hose runs from the top of the washer fluid too to where??
I think you're confusing the electrical connection coming from the same area on the washer fluid tank (which leads to the vapor canister), with the actual vacuum line (that leads to the firewall)...
Pac J
May 17, 2020 10:44 AM
HoosierinWA
Oct 7, 2015 10:15 AM
3.8TransAM
Sep 27, 2015 08:37 PM
