no power after tpi swap
Old Apr 21, 2005 | 12:32 AM
intruder's Avatar
i recently swapped to tpi from tbi, got it all hooked up turned the key nothing happened, fuel pump don't run engine won'y turn over i have dash light and tail lights but nothing else. the car ran with the tbi in this 90 camaro so we put a l98 out of a 89 formula in it's pllace changed ecm engine harness what is wrong
Old Apr 21, 2005 | 04:54 AM
kevinc's Avatar
Car: 1982 Z28
Re: no power after tpi swap
The pin locations on connectors C100 and C207 change from year to year in most cases, so it's likely that your '89 engine harness has pins in different places than your '90 chassis connectors.
Time to dig up wiring diagrams for both vehicles and start mapping and moving pins.
Old Apr 21, 2005 | 10:10 AM
intruder's Avatar
ok, so does anyone have a wiring diagram of this harness so i can hopefully get it running
Old Apr 21, 2005 | 04:38 PM
kevinc's Avatar
Car: 1982 Z28
Matching the wires color to color is a good starting place. Not guaranteed 100% accurate but I'm seeing GM use the same or very similar color patterns for the various circuits.
I only have '82, '88, and '01 Helms manuals so I'm no help on diagrams for the two years you need. Maybe PM Trickster as he seems to have scans of some.
Old Apr 21, 2005 | 07:47 PM
intruder's Avatar
the camaro is originally a tbi car and we are going to tpi. is the camaro supposed to have speed density for tpi being it is a 90. if so would a S D harness fix this problem?
Old Apr 24, 2005 | 11:46 AM
intruder's Avatar
bump
Old Apr 24, 2005 | 12:33 PM
JB97C5's Avatar
Car: Silver 1980 Corvette (L82 w/TPI)
Engine: L82
Transmission: TH350
Go to your local public library and pull up a Mitchell systems diagram for both years.
Actually, pull out 3 schematics-
1 Your TBI year.
2 Your TPI year.
3 And what TPI would look like had it been on your car.
Now, what I would do is to gather up a couple of markers, highlighters, or colored pencils. Then, mark the systems that you share original connections with in dark black. Then mark what you did to change your harness in red. Leave what you haven't finished (or what is left to complete) in blue. You'll knock it out by process of elimination.
I don't have a "fix all" way to help you- but if you wire trace by harness matched to what you have done- your harness will be better than a run of the mill SD harness.
However, you may have missed a power wire or a ground to the computer. Are you flashing codes?
Old Apr 24, 2005 | 01:39 PM
intruder's Avatar
no code flash cause i haven't had it started. the tpi harness i am using at this time is from a 89 formula, (maf) the car won't do anything car will not turn over, fuel pump won't work nothing under the hood will work.. the onky thing that does is head lights, turn signals the items on the original harness of the camaro. anything on the engine harness side don't i do have the c100 diagram from the formula and camaro i see that there are several that are the same and several that are not. cause of the bird having headlight doors and such but i don't understand a damn thing about wiring
Vintageracer
Jan 10, 2020 05:33 PM
InfinityShade
Aug 22, 2015 08:00 PM
stalkier
Aug 13, 2015 12:59 PM
Sanjay
Aug 12, 2015 03:41 PM
