Next best modification for my setup
Old Apr 25, 2005 | 07:03 PM
trueburton's Avatar
Car: '88 Red Trans Am w/ T-tops
I am on a college student budget here but I can always use a few more ponies. What is the most efficient upgrade i should get next for my car. Looking for something under 200 bucks. Thanks.
Old Apr 25, 2005 | 07:17 PM
ator's Avatar
Car: 92 Firebird Formula
Transmission: 700 R4, 3.73 rear
Re: Next best modification for my setup
Headers!
Old Apr 26, 2005 | 12:42 PM
brutalform's Avatar
Underdrive pulleys.
Old Apr 26, 2005 | 12:46 PM
trueburton's Avatar
I was thinking of both of those. But i think when i do the headers i'm gonna go all out and do the full dual exhaust. So i think headers are out of the question for now. Any other suggestions? I was thinking short throw shifter or maybe SFC's?
Old Apr 26, 2005 | 12:47 PM
KiLLJ0Y's Avatar
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
i went to home depot, and got parts to make my own CAI.. definatley feel the difference in the Butt Dyno.. total cost including the 6" K&N cone filter was 60$..
Old Apr 26, 2005 | 12:51 PM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
Transmission: TH-700-R4
[b]i went to home depot, and got parts to make my own CAI.. definatley feel the difference in the Butt Dyno.. total cost including the 6" K&N cone filter was 60$..
He already has a K&N...
Originally posted by brutalform
Underdrive pulleys.
Underdrive Crank Pulley only...
Its like
$50 plus new belt ($25)
Ok mod for the money....
Old Apr 26, 2005 | 12:59 PM
trueburton's Avatar
Its like
Yes i have a K&N in the stock location but have been thinking of modifying it into a CAI style. What about the crank pulley only? Why not go with the full set except for the money?
Old Apr 26, 2005 | 01:16 PM
KiLLJ0Y's Avatar
Engine: 4.3 Turbo
Transmission: 4L60
the pulley's are a good idea.. you can get the March ones for 99$ at summit.. get the crank and alternator.. they make them to work with one another other wise the alt could suffer.. i know because i did just the crank and destroyed an alt.. you dont loose any charge so dont worry about it.
i already knew he had drop filters.. but drop filters pale in comparision to a huge cone.. the stock intake system is a restriction. if you bought the pulleys and did the charge air cooler.. you would feel a nice difference in throttle response.
also you could get an aluminum drive shaft for 120$
just idea's.. are you looking for performance or handling?
Old Apr 26, 2005 | 01:21 PM
trueburton's Avatar
That's what i have been trying to balance out. Not sure what i would rather have. Performance is always good to have but it is my daily driver minus winters so handling would be a nice upgrade? I think i am looking more for performance though.
Old Apr 26, 2005 | 01:26 PM
KiLLJ0Y's Avatar
Engine: 4.3 Turbo
Transmission: 4L60
or you could save the dough.. and save for a edlebrock base intake and some runners..
but if you're like me.. money burns a hole in my pocket..
Old Apr 26, 2005 | 01:32 PM
trueburton's Avatar
yeah that's not gonna happen right now. PLus i just polished my runners this winter. I can't replace them already.
Old Apr 26, 2005 | 01:47 PM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
DO NOT get the alternator pulley....I thought the same thing,I have a stock electrical and sound system and thought everything would be ok.I was nearly stalling at red lights because the voltage was so low.Big strain on the battery and alternator and decided to ditch it.I'd recommend just the crank pulley from ASP.
Old Apr 26, 2005 | 02:29 PM
KiLLJ0Y's Avatar
Engine: 4.3 Turbo
Transmission: 4L60
then you already had low voltage in your battery... ive got the stock alt.. from 92.. and been running the alt pulley for 2.5 years.. with NO problems.. they work.. just everything else better be working as well..
just an FYI.. stock volt meter suck at giving accurate reading.. right now mine reads 14.5 but if you really check it.. its 13
also if you are using stereo equipment that is a drain on the battery.. yeah your going to have issues with it.
Old Apr 26, 2005 | 07:38 PM
conlinj's Avatar
maybe you were like me and got the performance series instead of the power and amp series. The performance series gave me charging problems - at night with the headlights and everything on the car would shut off, switch to the power and amp series (just smaller alt pulley) never had a problem again.
-Jim
Old Apr 26, 2005 | 07:59 PM
orange86's Avatar
were could i get the affore mentioned aluminum drive shaft???
Old Apr 26, 2005 | 08:17 PM
KiLLJ0Y's Avatar
Engine: 4.3 Turbo
Transmission: 4L60
ebay.. got mine for 92$ plus shipping.. or try a 4th gen salvage yard..
such as billygrahams in AL
Old Apr 26, 2005 | 08:19 PM
305q_ta86's Avatar
Car: 1993 Nissan 240sx
Engine: Turbo KA24DE
Transmission: 5 spd
Axle/Gears: 4.08 VLSD
nah, I'd say sfc's. Not much in the extra ponies dept, but it will help you a lot. Or headers, but you already said no to that.. How about a cam, if you can install it yourself?
Old Apr 26, 2005 | 08:28 PM
orange86's Avatar
Thanks for the info killjoy, do you know of any strictly f body salvage yards in Colorado, I searched but came up empty handed, any info is greatly appreciated. Thanks guys
Old Apr 26, 2005 | 08:57 PM
91z28ss's Avatar
Car: 1991 Z28 convertible camaro
Engine: 383 superram
Transmission: Level 4 Vigilante 3000
Axle/Gears: 3:42,Torsen, moser axles LPW girdle
Hey!
What gear are you running? If you change from a 3:08 to a 3:42 for exemple, it will make a noticable difference...
Old Apr 27, 2005 | 09:56 AM
trueburton's Avatar
yeah i have stock gears but i think for now i will keep the stock gears for fuel economy.
Old Apr 27, 2005 | 10:38 AM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Originally posted by trueburton.yeah i have stock gears but i think for now i will keep the stock gears for fuel economy.
You're running a 5-Speed, swapping to 3.42 gears, from 3.08, won't make that much of a significant difference in gas consumation...
If I were you though, I'd go with a cam, then port match the intake, plenum and runners. Get yourself a used (but good) cam, then grab yourself an AFPR (and up the fuel pressure). You could probably find both (used cam, and AFPR) for under $200.00 total, if you do you're homework...
Old Apr 27, 2005 | 10:42 AM
trueburton's Avatar
already have the AFPR. How hard to install new cam?
Old Apr 27, 2005 | 10:51 AM
If you're fairly new to swapping cam's, you might want to install a set of 1.6 rocker arms instead.... it's much less of a headache.
The reason why I would go with a cam, then port match the entire valvetrain, is because you can buy yourself the biggest cold air induction kit in the world... but it won't do a damn of good if you're intake system is already severely limited.
Only so much air can squeeze through you're stock MAF, TB, Plenum, Runners, Intake... then finally the heads, with a 'giant' CAI set-up in front of the engine.
But a good porting job, and good cam, will make sure that whatever air does get into you're engine, it'll be sure to use it to it's fullest potenial.
If you're on a budget, save you're money.... as true power can only be found in the valvetrain (you're K&N filter's will finally serve their purpose, so keep them).
Old Apr 27, 2005 | 12:23 PM
trueburton's Avatar
I don't think i want to go that far with this engine. I will build up a 350 when i get it and put that in there. For now i'm just looking for small easy and cheap upgrades that will help the 350 out when i do get it.
Old Apr 27, 2005 | 01:04 PM
Originally posted by trueburton.I don't think i want to go that far with this engine. I will build up a 350 when i get it and put that in there. For now i'm just looking for small easy and cheap upgrades that will help the 350 out when i do get it.
If you don't want to go that deep, but still want to feel a difference in the 305 (while building a 350), go with some gears. An exhaust, or CAI will not get you out of the hole quicker than a set of gears will...
Old Apr 27, 2005 | 11:49 PM
trueburton's Avatar
yeah i will get the gears soon but the CAI is cheaper. So I'll prolly go with that for starters.
Old Apr 27, 2005 | 11:51 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Sub-frame connectors. By far.
Old Apr 28, 2005 | 11:02 AM
KiLLJ0Y's Avatar
Engine: 4.3 Turbo
Transmission: 4L60
just so you know... ahead of time.. if you've never installed a set of gears.. you really REALLY need someone with you who has.. you dont want to set the pinion depth wrong..
also a set of gears, you need to get the install kit.. wich is 100$ or 79$ depending on what you get with it..
if you pay someone to install it.. you're looking at a 250-400$ job in labor..
basically EVERYTHING from the rear has to come off.. wheels, calipers(or drums if you have them) axels, posi(if you have it) ect.
guys gears is a good idea.. but you're forgetting 200$ is his limit for everything..
i still have 3:23's in mine.. bought a set of NEW GM 3:42's for 125$.. still need the install kit, then pay someone to do it.. im not messing with this..never done it..
to answer your other question.. i know there is another 4thgen yard only in Northern CA.. in Colorado i highly doubt it.. the biggest one is BillyGrahams.. there is also a guy on Ebay, i want to say his name is pick_Apart.. or something.. they have A LOT of 4th gens.. i beleive they are in PA.. thats who i got my drive shaft from. i'll reseach the name for you and post it here.
Old Apr 28, 2005 | 11:08 AM
KiLLJ0Y's Avatar
Engine: 4.3 Turbo
Transmission: 4L60
yeah his Ebay name is Pick_A_part, there is also another guy here in CA, 4thgen dismanteler.. ebay name is edemerson
ive bought several parts from bother guys, very cheap, and fast shipping from both..
Old Apr 28, 2005 | 01:23 PM
Originally posted by KiLLJ0Y.just so you know... ahead of time.. if you've never installed a set of gears, you really REALLY need someone with you who has...
I totally agree. But, remember, this is the hobby that we've (he's) chosen, and thus he has to learn somehow. Personally, I would never let anyone work on my car... unless I knew them, and their work, very well.
Yes, he won't be able to get it right his first time without assistance, but, this is how he'll learn. I'm sure he won't be willing to do such a swap right 'now', but to dismiss the concept too quickly is a mistake. If he stepped up to 3.55 gears... he will feel it much more than a CAI, or exhaust (combined), and his mpg will not suffer much.
Originally posted by KiLLJ0Y.guys gears is a good idea.. but you're forgetting 200$ is his limit for everything..
If he put's it off for another month, he'll have more than enough (and it'll be well worth the wait, believe me, TrueBurton)....
KillJoy, over 1,000 posts in just two months? Sweet!
Old Apr 28, 2005 | 01:34 PM
trueburton's Avatar
Thanks for the input guys... My brother is a mechanic so he would be helping me with the install of the gears but i'm not gonna do that until next year prolly. I'm gonna go with 3.42 gears FYI.
Old Apr 28, 2005 | 01:51 PM
Originally posted by trueburton.I'm gonna go with 3.42 gears FYI.
FYI??
Good choice though. I have a habit of thinking long term, and the reason why I'd go with 3.55's over 3.42's (there isn't a noticeable difference in mpg with a 5-speed, believe me)... is if you ever decided to swap in a 6-speed.
But, 3.42's are a great choice. I had them with my old 700R4, with TCI stall, and she launched extremely well. Good luck whichever way you go bro!
Pac J
May 17, 2020 10:44 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
2012sergen11
Oct 13, 2015 07:38 PM
R13_Braz
Sep 18, 2015 05:00 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
