several probs with TPI
Old Apr 28, 2005 | 09:11 PM
89formulaws6350's Avatar
Car: 87 firebird,89 formula,74 Olds that runs 12.34
Engine: LG4,L98,455Olds
Transmission: 7004r,7004r,th350
I own an 89 formula with a 350 TPI. First , the lowest I can get it to idle is 750 rpm but I think that is caused by the vacuum leak. There is a hose that is hooked up to the Cruise Control diaphram but I dont know where it hooks up to the engine. I found it laying behind the distibutor. Also it doesnt seem like it wants to rev for nothing! When I hit the gas it bogs so bad it sounds like its going to shut off and then it start revving very slow. I had a mechanic work on it to make it run right and 1000 dollars later I think it might run worse! I do have a new cap and rotor and new plugs and plug wires. BTW no check engine soon light so I guess the computer thinks the engine is running fine! Any help would be appreciated!
Old Apr 28, 2005 | 09:30 PM
83Firebird420's Avatar
Car: 87 GTA 120,000k, 90 CRX Si
Engine: 5.7 TPI, 1.6L 16 valve SOHC
Transmission: 700r4, 5spd std
possible clogged cat?
Old Apr 29, 2005 | 08:57 PM
redrummer's Avatar
Car: '88 Trans Am GTA
Engine: 5.7L L98
Axle/Gears: 3.27 Aussie 9 Bolt
That hose connects to the passenger side of your plenum. It's on the side all the way to the back. It's easy to see. There's three ports on the plenum back there.
Old Apr 29, 2005 | 09:22 PM
Thanks for the replys. I guess I will check the cat and get the vacuum hose hooked up and see how it runs. Some how I dont think that will fix it completely but its gotta make it better!
Old May 2, 2005 | 10:53 AM
Well I found the major problem. Burned plug wire. But I
Old May 2, 2005 | 10:54 AM
But I still have a tip in bog. What can cause this?
84z96L31vortec
Aug 20, 2017 12:16 AM
billybob6110
Sep 24, 2016 09:50 AM
z28addict8490
Sep 5, 2015 03:56 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
