Looking for detailed picture of all Vacuum hoses
Old Apr 28, 2005 | 09:59 PM
IonNight's Avatar
Car: 1986 Iroc Z
Engine: Truck 305 /Bored .30 Flat Pistons/ Crane Cam
Transmission: Corvette 700R4
I saw all the pictures on this site of the vacuum hoses and still I am missing one even with it hooked up like the pictures..... Also I dont see where to run the windshield washer fluid hose that is on the top of the cap.
thanks
Jordan
Old Apr 29, 2005 | 04:23 PM
IonNight's Avatar
Car: 1986 Iroc Z
*Bump * help :[
Old Apr 29, 2005 | 04:25 PM
speed88's Avatar
Car: 1988 Trans Am GTA
Engine: 383
What one are you missing?
Old Apr 29, 2005 | 06:03 PM
TheGreatJ's Avatar
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
Transmission: 700R, T56, 700R4
How many vac. ports are on the pass. side rear of your plenum? For a MAF car, there should only be 2. If you have 3 ports then someone has put a newer speed-density style plenum on there, and the third port is for the MAP sensor that your car doesn't use. If this is the case just cap the port.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
chubsworth
Aug 26, 2015 02:34 AM
Jote4805
Aug 25, 2015 06:11 PM
