Non air headers, issues?
Car: 85 z28
Engine: 305 tpi (I got screwed, supposed 350)
Transmission: 700r4, b&m shiftkit
I have a set of hedman headers for my tpi 350 from an 89 iroc, if I install these will I have any issues? If so what? Thanks.
Car: '88 Trans Am GTA
Engine: 5.7L L98
Axle/Gears: 3.27 Aussie 9 Bolt
Car: 89 Formula
Engine: 5.7 TPI
i put headers on my 89 formula and they didnt have A.I.R. The only problem I had was when I left the shop, about a half a mile away the SES light came on. But then after driving home it turned off, dont know which code it was though so it may not even be anything related.
Car: Which one?
Engine: 355
Transmission: 465
Been covered in the PROM section I believe, there is some code that "tells" the ECM that AIR is on sometimes, which could lead to a false lean condition.
Tons of people run stock with AIR removed and no issues, if anything, it probably slightly affects MPG.
A I R
Yep, removed my air pump on an otherwise stock L98 Iroc, no codes, no issues, and it did affect my gas mileage, picked up on average of 1-2 mpg, now getting slightly over 20 mpg driving in the city. Larry.
1992 Trans Am
May 10, 2023 07:19 PM
mdtoren
Aug 16, 2015 05:45 PM
