HSR Fuel lines
Old May 1, 2005 | 11:46 PM
RSblkcam's Avatar
Car: 1991 Formula
Engine: 350 HSR
Transmission: TH-700R4
Axle/Gears: 10 bolt 3.73
HSR Fuel lines
I am about to do a HSR swap and I know you have to do changes to the plumbing and on stealthram.com, they have a kit for this, but the link doesn't work anymore, so is there another place that sells the lines or do I need to pick and match parts from other resources? Thanks.
Old May 2, 2005 | 12:53 AM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
email stealthram.com and tell them the link dont work and ask for the kit info. I cut my stock lines and replaced with new ones when I had HSR.
Old May 2, 2005 | 02:23 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I used part of the stock TPI hard line that attached to the rubber line and had a shop weld a -6an end on it and just ran braided lines to the HSR
Old May 2, 2005 | 10:43 PM
RSblkcam's Avatar
Car: 1991 Formula
Engine: 350 HSR
So I can just buy some braided fuel lines and get a -6 AN part welded onto the stock line? Seems a little too good to be true. Thanks for the help.
Old May 3, 2005 | 01:55 AM
Zepher's Avatar
Yep.
The shop that did it charged me a total of $20, parts and labor.
They do make adaptor fittings, but I couldn't find any and Jegs didn't have any instock. The adaptors are basically the same as what I had made up.
Old May 3, 2005 | 09:27 AM
RSblkcam's Avatar
Car: 1991 Formula
Engine: 350 HSR
Are there any other online stores that would sell these adapters? Also, since we are on the subject, what problems did you encounter during the installation and is there anything I should look out for? Thanks.
Old May 3, 2005 | 12:24 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
It is really easy. Just cut the connectors off of the body's hard lines and flare on some new connectors. Use braided 6AN line to go to the fuel rails and then use the supplied connectors that came with the fuel rail kit.
Old May 3, 2005 | 01:06 PM
Zepher's Avatar
Most people will install the adjustable regulator backwards so that the adjustment and vacuum line are facing away from the distributor, makes it easier to adjust and put the vacuum line on.
Old May 3, 2005 | 01:09 PM
Yep, no welding needed...
Old May 3, 2005 | 02:45 PM
RSblkcam's Avatar
Car: 1991 Formula
Engine: 350 HSR
Thanks for all the help guys. I'm pretty new to the plumbing of the car, so I'm not sure what these adapters look like or where to buy these and the braided lines. Pics would be great. Thanks again.
Old May 3, 2005 | 03:18 PM
Zepher's Avatar
an Industrial Hydraulic Line shop should have all the fittings, Hoses and adaptors.
Old May 3, 2005 | 08:42 PM
RSblkcam's Avatar
Car: 1991 Formula
Engine: 350 HSR
Was this swap pretty straight forward or did you run into some problems? I'm going to be using my stock throttle body and I've heard of some issues with that. Any heads up would be greatly appreciated.
Old Oct 1, 2017 | 09:44 PM
Captainfernny's Avatar
Car: 1988 GTA Trans Am
Engine: 5.7
Re: HSR Fuel lines
Really old but does anyone remember the fitting size or adapter sizes?
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
