TPI 305 rpm questions
Old May 2, 2005 | 01:12 PM
fixin87formula's Avatar
Car: 1987 Formula T-top
Transmission: 5-speed
Will I be able to get the TPi on my 305 rev and pull well to 5500 RPM. Its my understanding that the TPi was designed for the 305 therefore it doesn't restrict the 305 like it does the 350. I have already ported the plemun but I was going to go in and smooth everything out, just take off the slag and casting marks but not really open anything up. I'm also contemplating on weather or not to swap on a set of Vette heads or have my stockers ported. Also would an LT1 cam be a good upgrade for my car? Right now its a stock '87 LB9. Since I already have the "good" cam I was wondering if the LT1 would be worth swapping in. Just one more question. Since my car is MAF if I do a cam swap will I have to have an eprom burnt for my car?
Bob
Old May 2, 2005 | 01:37 PM
RednGold86Z's Avatar
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
Fellow Iowan (well I'm formerly Iowan),
I don't have much advice on the intake porting other than there's quite a bit of room for improvement, even for a 305.
But, change the cam while the intake is off. Something like a 2032 crane emissions legal roller cam or a little smaller will wake up that 305.
Headwork? You'd want to mill the L98 aluminum heads to get the compression back (58cc vs 54cc and might as well up the CR a tad). You wouldn't want to spend too much time on the stock heads, other than it's good practice. Others have ported the stock heads with ok results, so search those out.
For a 305, I'd only do a cam (including pushrods and valve springs), some headers and catback, and a torque converter (if you had an automatic, which you don't - 2400 RPM or so). Also get the rear gears up a little (3.23, 3.27, 3.42, 3.45, 3.73 or 4.11). Save the rest of your money for a 383.
The stock programming should get it running decently, unless you change injectors, if you're sqweamish about the chip tuning thing. MAF is quite forgiving, and as long as the changes are as simple as I've provided, should be "good enough" for most people. If it gives you heck, well, that's what this website is for.
Old May 2, 2005 | 04:24 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
It's possible to get your 305 to rev to 5500rpm without the power dropping off. You'll need to do more than remove the casting marks though. You really want to either port your base or replace it with an aftermarket one. The runners are the most restrictive thing on there, so you'll need to swap them out while you're at it.
The 'Vette heads work well with the 305. I have them in my combo and I'm very happy with them.
How much are you looking to spend?
Old May 2, 2005 | 04:45 PM
How much do I want to spend? Not Much See I don't religously race this car and right now I am spending a bunch on body work and getting it to look good. I would just ike to get it to rev past 5000 without falling on its nose preferably around 5500. I already have a set of vette heads so all I need is the cam. The reason I want to go with a LT1 is cause they are really cheap and should get the job done for me. As far as porting the base and runners how far do you guys think I will have to go to get it to pull higher. Should I siameese the base, or just open it up a bit? How bout the runners aftermarket pieces are kind of out of the question cause damn they are alot of bones. What can I do to them to get them to flow better? Here are my mods so far and this has been a hell of a improvment over stock.
-Modified MAF
-TB coolant bypass
-Air foil
-Open filter element
-Port Plenum
-Adjustable fuel pressure regulator
-Headers
-Aftermarket Y and exhaust 3"
-Underdrive pully
Oh BTW my car does have the Borg Posi diff with 3.45's and the 5-speed
Old May 2, 2005 | 05:12 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Well if you already have the heads get a decent cam and put it all together. As for the runners, to mod what you have you'll have to cut them up and try to turn them into a home made SLP style runner. There was at least one person on here that did that. As for the base, I just bought an aftermarket one for my setup.
Old May 2, 2005 | 08:03 PM
IROCZ4BD3's Avatar
Car: 89 IROC
Engine: 350 HSR
Transmission: modified 700R4
Mine does.Shift outta first at 5800 rpms.
Fast355
Dec 2, 2016 06:33 PM
redmaroz
Aug 16, 2015 11:40 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 10, 2015 07:44 AM
