HELP!! TPI Problems Maybe EGR?
Old May 3, 2005 | 02:06 PM
730tpi's Avatar
I just picked up an 87 Trans Am and noticed that anything under a quarter throttle the car kind of bogs and stumbles a little bit it also stalls out once and a while usually when i'm backing up or driving around 5 miles an hour. Anything over a quarter throttle the car drives fine. I hear that this can be caused by a bad egr valve is there any way to test it it seems fine. Also when i'm driving and I let off of the gas the car kind of surges a little bit. Anyone know what could be causing this? Thanks - Justin
Old May 3, 2005 | 02:22 PM
730tpi's Avatar
I forgot to mention its a 305 with TPI. - Justin
Old May 3, 2005 | 04:21 PM
305TA85's Avatar
Car: 85 T/A & 98 T/A
Engine: 305 tpi/ 5.7 LS1
Transmission: 700 r4/ T-56
Axle/Gears: 3.23/ 3.42
HAVE THE SAME PROBLEM
i'll save you the time from searching though most people won't stop to help only say go search. It can be that the iac, tps, cts, a leaky cooling system, vacuum leak, knock sensor however slight engine noises can throw a knock sensor off like a lose rocker, the list just goes on. unfortunately as the same problem for many different people each little thing seems to help as little i had a manifold leak and that make it ru n better but not perfect still stalls. I just got my car i dont know if you did but check the plugs are in tight mine were lose on a few of them if this helps good it could very well be the egr i havent messed with mine cause i dont want a big project right now. Check the fuel pressure as well autozone has the guage.
mdtoren
Aug 23, 2015 12:52 PM
Out-Cast
Aug 17, 2015 10:57 AM
mdtoren
Aug 16, 2015 05:45 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
