30# injectors for 383?
Old May 9, 2005 | 10:16 PM
Derrickclerici's Avatar
Car: 71 Chevelle / TPI
Engine: 383
I have built a 383 described below and want to know if the 30# injectors I have will be too big. I have fired it up without any sort of scan software (still figuring out which one to get) and it runs way way rich and rough. I am not sure if it is in limp mode or not since I haven't gotten software up yet. Any recommendations on software and injectors would be appreciated. I am somewhat new to TPI.
Vortec 383
mildly ported Vortec heads
ZZ4 Roller cam
9.2:1 comp
SD Vortec TPI
Stock runners and plenum
Headers with heated O2
'86 IROC TPI system (5.0)
'89 350 PROM and cold start injector disabled
I would like to get it running decent for now and dial it in later. The engine is in a '71 Chevelle that is still a long way from being on the road.
Old May 9, 2005 | 10:40 PM
Guest
Guest
Posts: n/a
Stock prom with 30#'ers? Yikes, yea its rich. Way rich.
Old May 9, 2005 | 10:45 PM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
30lbers are what I use on my 388+. The ECM is reprogrammed, and I use an adjustable fuel pressure regulator at about 45psi static pressure.
Old May 9, 2005 | 11:44 PM
89Warbird's Avatar
Car: 1989 GTA Nighthawk
Engine: 389 CID TPI
Transmission: TCI 700R4
Axle/Gears: 9 bolt 3.23
I'm doing it with a custom chip and AFPR.
Old May 10, 2005 | 07:35 PM
Engine: 383
Would 24# injectors be a better choice? I was thinking about getting a set off of ebay.
Old May 10, 2005 | 07:39 PM
KiLLJ0Y's Avatar
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
prom tuning... prom tuning... prom tuning..
hey did i mention prom tuning?
Old May 10, 2005 | 08:46 PM
Engine: 383
I plan to play with that eventually but I need something now to get it close enough to move the car under it's own power to the body shop and in and out of the garage etc. Right now it just coughs smokes and fouls spark plugs. I did have a scanner on it a long time ago and it was leaning itself to it's llimit (108 maybe) and it was still pouring smoke. I just don't have the time to fiddle with making my own proms
Derrick
Old May 10, 2005 | 08:57 PM
robsgta's Avatar
Car: 88GTAnotchbac/91 -Z/66 Chevelle
Engine: All strokers
Transmission: Pro built 700r4's
Then get 24 pounders
Old May 10, 2005 | 09:43 PM
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
In the mean time check the Coolant Temperature Sensor resistance.
For example with the engine cold, and the resistance is around 13k ohms it's correct for 20°F which is within range, and the ECM won't set a code, but it's not winter and the ambient temerpature is 70°F the resistance should be 3.4K ohms. The ECM will dump fuel to warm it up, and continue to do so because the sensor reading is offset.
Old May 10, 2005 | 10:05 PM
hot68's Avatar
Car: 68
Engine: 383
Transmission: homebuilt 4l60
Im running a 383 with Performer RPM heads and "Lt 4 hot Cam" and a First" TPI setup. Both First injections and TPIS recommended 24's over 30's so thats what I went with. FWIW mine is also in a chevelle...
Old May 11, 2005 | 07:27 PM
robsgta's Avatar
garcia63 - The ECM will dump fuel to warm it up
The ecm will lean out the mix to help it run warmer not vice versa.
24 lb injectors will have no problem supporting a naturally aspirated 383 if they do its probably the fact your pump isnt up to the push. I had a small fuel starvation problem on my GTA at one point (weak fuel pump)so I got an inline pump and the fuel pressure runs strong all of the time.
Old May 12, 2005 | 08:36 PM
Engine: 383
I am going to get some 24#s and check the the temp sensor. Thanks for everyone's input, this is a great site.
Derrick
Old May 12, 2005 | 10:50 PM
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
Derrick
Hey, keep us posted on your progress.
Old May 16, 2005 | 02:55 PM
primo's Avatar
The 30#s are OK, I have 30 on my 383, you need to do some eprom burning. Runing 12.4 s ET.
Old May 16, 2005 | 06:41 PM
robsgta's Avatar
But he can run 24 pounders with no prom tuning
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
earlpote
Sep 12, 2015 11:55 AM
Keiffer76
Sep 9, 2015 08:52 PM
