Help me pick out a Cam...
Old May 9, 2005 | 11:11 PM
86IROCNJ's Avatar
Car: 86 Iroc-Z28
Engine: FB385
Please. I have a fastburn crate motor with the lt4 hot cam currently. I am looking for something more now since I am taking out my radiator to install new dual fans. My accessories are easy to deal with and take off of the motor so I think now is a good time to change out the cam while the motor is IN the car. I have the MiniRam III intake with 58mm tb and Hooker long tubes. The car is MAF for now and is running an Ed Wright chip currently. So far so good with how the car runs. I really need to get it to a tuning facility to see what is truely going on with it though. Before I do that and spend the money to have it dynoed and or tuned, I would like to swap in a cam before hand while I can. What I want now is a little more power from a cam swap. I plan on swapping to either DFI or SD next year and also install a Procharger so I would like a blower freindly cam also. This is more than likely asking for two different things at once but if I can find something that will work well, than I will go with it. Any suggestions, experiences, opinions(good or bad) are welcome. Thanks
Old May 10, 2005 | 12:15 PM
86IROCNJ's Avatar
Car: 86 Iroc-Z28
Engine: FB385
Does anyone have a similar setup? heads, intake, cam? I know of a guy who did the same exact thing (which is where I got the idea to run a blower next year) but I did not find out what cam he went with. He worked the heads, installed new pistons, put in a different cam and ran the MR with I believe an A4. The info I have claims that he ran low 11s consistantly in the qtr mile. Any cam suggestions would be cool. I want to hear from people who have done it than some tech guy over the phone.
Old May 10, 2005 | 09:48 PM
burnout88's Avatar
Car: 88 IROC
Axle/Gears: 10 bolt 3.73
What times do you run with the current setup?
Old May 11, 2005 | 04:21 PM
86IROCNJ's Avatar
Car: 86 Iroc-Z28
Engine: FB385
I do not have any. The motor has less than 50 miles on it. When I bought the lt4 cam I thought I was going with a carb so I sat on it for a while and as time went by I upgraded mostly everything. This is why I am swapping out the fan now, because I have money. Like I said, it will be fairly easy to do now so I would like to put in another cam for some more power. This car was also going to be a daily driver but that has now changed so as you can see, my plans have changed a lot from when I first purchased the motor. I just wish I knew all of this a few years back when I decided to do the motor swap. I would have saved time and money. Funny enough, those two things have led me up to this point. Just a "poor" college kid worked to death trying to blow his cash on his car.
Old May 11, 2005 | 06:44 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
If you are going to put a blower on the car that changes everything. I would call a cam manufacturor for their recomendation. Your compression ratio will also determine how much boost you can use. Allen
Old May 15, 2005 | 06:02 PM
86IROCNJ's Avatar
Car: 86 Iroc-Z28
Engine: FB385
Thanks for the reply Allen. That is what is tuff. Since I do not have the money for everything at once, it makes it difficult to get the best parts now so I can use it and get the most out of it. I don't want to compromise anymore. So with that, those with MRs n/a, what cams have you used, also what size motor are you running it on? Closer to a 350ci would be best for referance. thanks again
Old May 16, 2005 | 06:58 AM
contact's Avatar
Engine: sbc 350
86',
what rpm range, do you want?
How much idle smoothness, do you need?
Old May 16, 2005 | 06:33 PM
86IROCNJ's Avatar
Car: 86 Iroc-Z28
Engine: FB385
Well, now that I have a reliable daily driver, driveability is not a big issue. I will drive it a lot and not just on Sundays, maybe 2-300 miles a week during nice weather. I built it to enjoy it, not to look at it. Enjoying it means driving it. As far as an rmp range, right now I believe they recommend a 5800rpm max on the zz4 bottom end. So I expect this motor to run up to 6000rpm as it sits. With the MR it will be tough to get a useable powerband down low, I know this. As it sits I have not gone up past 4500 to break in the motor. I still have some work to do to get it in a state where I can clock on some break in miles. Mainly new fans.
Old May 19, 2005 | 09:48 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
You could try the CC306. Gm also has the 847 and 846 cams.
RedLeader289
May 28, 2019 01:47 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
jaridjohn
Oct 5, 2015 07:01 AM
TheCardinal
Exterior Parts for Sale
Oct 1, 2015 07:40 PM
92projectcamaro
Sep 29, 2015 07:07 PM
