Hats Off To The Moderator!!!!
Old May 11, 2005 | 09:06 PM
85irocrebuildtp's Avatar
Car: 85 iroc
Engine: 350/305heads/rv cam....
Transmission: 700r
Thank you for the opportunity to talk about my little project car that is on the road after 2 years of hard work isolating buildout we did.......the car is running great!!!!!
I am trying to tune my TPI for Low End Torque but I do drive on Freeway....so how do I tune my TPI for street driving showoff..................
This is a mild cam upgrade (going for snappy undersize approach, cam spec....duration @.050 intake 204, 214 Exhaust, hydraulic Elgin cam, model RV Cam(Recreational Vehiclec Cam..RV....) E923P...
MAJOR- kept 305 heads for racecar setup...totally reconditioned stock....
bottom block - 350 bored .030 flat top pistons four valve relief...
52mm thottle body...air foil.....aftermarket MAF with screens
twenty four lb/hr injectors.....FASTCHIP.com chip to spec....SLP 1 5/8 headers....3" exhaust....FRAME ALL WELDED upper strut, steering box, front to back siderails, aluminum drive shaft, stock rearend, LCA's, Panhard
timing 7 degrees
fuel pressure forty seven PSI
3 wire O2 ------ Air/Fuel meter pretty much yellow middle road not rich not lean but i do get red alot... "lean" when the let off WOT
so thats the car.........she goes but not a rocket but fast
how do i get more
new heads for motor
more fuel pressure for TPI?
so how do i get TPI better with the car?
I am sorry if i am asking the question in the wrong forum...but I would like the MODERATORS opinion on what I can do now with this TPI (my reason for rebuilding this 85 torque/power car)
i love the 85 iroc I am rebuilding and I learn tons on this web site....my hats is off to the moderator........keepe GREAT WORK!
Old May 11, 2005 | 09:10 PM
Car: 85 iroc
Transmission: 700r
CRANK
NEW STOCK TURNED 10/10
Old May 11, 2005 | 09:13 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Heads is where the power is at. You did not mention your exhaust system but that should be upgraded from new headers to the tail pipe.
Old May 11, 2005 | 09:28 PM
Car: 85 iroc
Transmission: 700r
i was thinking heads now...
o.k.
heads.....what kind for my 3rd gen motor? what about a torque converter? will my 700r handle it? i think i am 350hp right now....that i thought was the limit for 700r tranny's?
Old May 11, 2005 | 09:31 PM
TPI's Avatar
Car: '89 Trans AM/'88 GTA
Engine: (2) Tuned Port L98's
Re: i was thinking heads now...
Originally posted by 85irocrebuildtp
o.k.
..lol
350hp huh ..
you got any papers? cause from what I hear 350hp is not that easy of a task on a TPI motor. Tho, you mods could back that up .. i dunno.
as far as I know Ive seen 10sec Camaros use 700r4s in thier cars. I think its safe to say your in good shape
Old May 11, 2005 | 09:37 PM
Car: 85 iroc
Transmission: 700r
Re: Re: i was thinking heads now...
Originally posted by TPI
..lol
350hp huh ..
well i was thinking of rebuilding the internals on my 700r, i can do that within a week...i got a tranny shop i know good.........to handle the added 500 maybe hp?
what heads now and torque converter? will fastchip.com need to give me a new chip? "tUNING THE tpi"
Old May 11, 2005 | 09:42 PM
Car: 1989 GTA
Engine: 369 TPI
Heads? Depends on how deep your wallet is. Lots of good heads in the $1000-1200 range. AFR's are a little more pricey. Allen
Old May 11, 2005 | 09:45 PM
TPI's Avatar
How many miles are on the transmission?
if its fairly young. Id just drain all the ATF out of it. Replace front pump seal and rear .. replace tranny filter (inside tranny pan) and
fill her up with some nice Kendall ATF or something.
I did that to mine just before we dropped the block in
I havent had any trouble since.
as for heads.. you cant be too hasty
you might wanna wait for an advanced F-body guy, because that question is a tad outta my league.
BTW, I just finished my build very similar to yours.
But I went with a diffrent cam and did headwork.
I should have papers for mine tho
Old May 11, 2005 | 09:46 PM
Car: 85 iroc
Transmission: 700r
heads
i dont know?
i spend 1200 on heads and get how much more hp?
i go with AFR's and get......WHAT KIND OF BONUS?...
i am willing to spend more on my rebuild
now will my rear end hold up after this mod?
or do i gotta goto a 12 bolt?
Old May 11, 2005 | 09:47 PM
TPI's Avatar
A new chip for what?
Old May 11, 2005 | 10:05 PM
Car: 85 iroc
Transmission: 700r
i am a morroon
lets see the chip runs the car i change my torque converter and i need to change my chip for that i thought? like i said i am a moroon i do not know and hence this thread....i am only trying to make my car better.... this is a very cheap way of figuring out my next step with this car..........
Old May 11, 2005 | 10:06 PM
cali92RS's Avatar
Car: White KSwisses
Engine: 5.3L Gen III
Heads are a huge part of the equation, and I think AFRs should be your choice...
In fact, I know a guy who did 12.3x with a real mild cam (LPE 219) a super ram, and untouched AFR heads. It idled smooth and even passed strict cali's strict smog test.
Old May 11, 2005 | 10:11 PM
Car: 85 iroc
Transmission: 700r
afr
12.3x is an AFR HEAD?
the cam is same and i can hook a cold air induction for same ram, my horses are not thatn large for that much more air in my opinion....., i like my hood.......... i think i am NASCAR...........
i don't even have 2 touch my gas pedal to start my baby up!!!!
Old May 11, 2005 | 10:14 PM
cali92RS's Avatar
Car: White KSwisses
Re: afr
12.3x is ET in a 1/4 mile run
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
ban1one
Aftermarket Vendor Review
Sep 15, 2015 10:10 PM
